Old 10-01-2019, 04:50 PM
Cannon51's Avatar
Cannon51 Cannon51 is offline
I think you should try one more time. See if you can find a torque spec and use a torque wrench. As you have seen the gear on the spindle and pulley will not hold without getting the flange nut tight.
Cannon
Old 10-01-2019, 05:45 PM
Captainmorgan Captainmorgan is offline
I greased them like crazy because I have already thought that might be the problem. I am using genuine parts. It isn't always the same one.
Old 10-01-2019, 06:41 PM
cooperino's Avatar
Then it's one of 2 things either they are not torqued to spec and loosen allowing the spline to strip or something comes in contact with the blade like a rock causing the blade to stop abruptly and causing the damage
Old 09-07-2025, 09:29 PM
Fish2017 Fish2017 is offline
I realize this is an older thread but I had a similar issue with my i1046 and wanted to post how I fixed it.
My i1046 ruined the pulley on the left side spindle. I purchased and installed a new spindle. It took all of 10 minutes to cut the shaft on the new one in half just below the upper nut. At that point I knew something else was causing the problem.
What I found is the two idler pulleys pivot on the same shaft and that pivot was rusted still. I pulled it all off, used a Dremel to remove the rust, put it back together and oiled the pivot. It has worked perfectly since then.
I did research buying new parts and one of the three involved was no longer available. At that point, I made the decision to clean up the original parts.
Hope this helps!
