Old 08-24-2011, 01:21 PM
blue83ranger blue83ranger is offline
Thanks for the idea. I'll look to see if it has it. I also took the intake off and it's clear and the gaskets were good. I bought some different plugs for it too. Only this time i bought what it's suppose to have. Before i just got what the guy that owns it put in it. and the right ones look to be a hotter plug and it seals with a taper on the plug and the guy had ones that use a gasket. I didn't try to start it yet but hopefully it'll either be the spark plugs or the spark advance thing (if it has one). thanks again for the idea. I'll let you know how it goes.
1983 ford ranger 302 4x4
1966 122 cub cadet
creeper, 3 point, rear pto, duals, 4 rear wheel weights
front blade
rear blade
Brinly plow
snow thrower
mower deck
Old 08-24-2011, 01:35 PM
FrankF3's Avatar
FrankF3 FrankF3 is offline
I agree..... Could be the 8th Wonder of the World....
1989 - Cub Cadet 1772
38" Lawn Sweeper #196483
60" Haban Mowing Deck #196374
Old 08-24-2011, 06:35 PM
Unless someone changed the engine, there is no spark advance.
I also agree there could be an obstruction in the intake manifold; if gas is not getting to the cylinders, that is definitely not an ignition problem. If you have spark, that isn't the problem, since the timing cannot be adjusted on these engines.
Old 08-24-2011, 09:25 PM
I had the intake off today and it was perfectly clean. The gaskets looked good yet but i put new ones on anyway. We also bought what the dealer told us were the plugs that it came with when new. I tried to start it and it did start. but usually if it does start, the next morning is when it has problems so tomorrow morning i'll see how it acts. If the problem the whole time was the wrong plugs i'm really going to feel dumb, but there were alot of problems with it i found and when it does run it runs so much better than when it first got here. I'll post back sometime tomorrow with the results, but i guess if it does start it's not a guarantee that it's permanently fixed
1966 122 cub cadet
front blade
rear blade
Brinly plow
snow thrower
mower deck
Old 08-29-2011, 01:14 PM
It's still running and the guy that owns it stoped by today and said except for when it was new it's never started so good. So it seems like the plugs, were at least the main problem with it. It did have other problems that i fixed. I useally see the guy on the weekends so if it acts up again i'll know about it. So thanks again for the help.
1966 122 cub cadet
front blade
rear blade
Brinly plow
snow thrower
mower deck
