Old 08-05-2011, 07:57 PM
blue83ranger blue83ranger is offline
Default 1862 won't start, i need some help
I'm working on a 1862, it has the 18 horse kohler command engine. the guy that owns it says he was using it to mow and on more than one occasion after it warms up good it just quits and wouldn't start for about 1/2 hour. So to me common sense would say that the coil gets hot and quits. So i bought a new coil and put it in. At first it seemed to be fixed but right before i was going to call the guy to pick it up i tried to start it and it wouldn't. The engine was completely cooled. So i took the carb off and cleaned every part of it thouroly with carb cleaner and compressed air. and put in brand new autolite plugs (that's what it had) blew out the gas hoses, no clogs. Put on a new fuel filter, took the fuel pump apart and couldn't see a thing wrong with it. And after i crank it for a bit if i start to take the gas line off the pump that goes to the carb there's pressure there, so that should be good. and i checked the compression but since it has a compression release i'm not sure what good that did me. It's 80psi and 82psi. The battery is fully charged as well and it spins over good. and i tried spraying some carb cleaner in the carb while cranking it over an it doesn't even fire. and it has good blue spark. I forget how many hours it has, i think it's around 500 and when it does run it runs pretty good, doesn't smoke, or make any noises but it takes awhile for it to idle down. any ideas? and thanks for any help.
1983 ford ranger 302 4x4
1966 122 cub cadet
creeper, 3 point, rear pto, duals, 4 rear wheel weights
front blade
rear blade
Brinly plow
snow thrower
mower deck
Old 08-06-2011, 09:17 AM
I don't know if this will help but, what I do is dump a little fuel into the carb and try to start it. If it fires then you know it's a fuel related problem and you can start troubleshooting that. If it doesn't then you probably have and ignition problem. Hopefully you can eliminate enough things and find your problem.
Old 08-12-2011, 01:55 PM
That's what i tried to do with the carb cleaner. It didn't fire at all. And the spark is nice and blue. and when i try to choke it after awhile i can smell gas but the plugs are dry. and i tired to find a gas leak but didn't see any.
1966 122 cub cadet
front blade
rear blade
Brinly plow
snow thrower
mower deck
Old 08-12-2011, 02:14 PM
young enthusiest's Avatar
Timing. I would think the timing might be off. Just speculating. I can't think of anything else
Old 08-12-2011, 02:33 PM
I'll check that out. But another weird part of this is that it occasionally starts up and runs great.
1966 122 cub cadet
front blade
rear blade
Brinly plow
snow thrower
mower deck
Old 08-12-2011, 02:38 PM
JOHN SCHUTTE's Avatar
JOHN SCHUTTE JOHN SCHUTTE is offline
Does it have a fuel shut off solenoid on the carb bowl?
Nemesis
Old 08-12-2011, 02:44 PM
yes it does, I literally just got done putting a brand new one on. And it still won't start. Sometimes the old one didn't work but the wire feeding it power always had power when the key was on.
1966 122 cub cadet
front blade
rear blade
Brinly plow
snow thrower
mower deck
Old 08-12-2011, 02:58 PM
Since we know the fuel shut off solenoid is good I would look at a few carb related items.
1. Inspect the vacum line from the valve cover to the carb for damage(mine was).
2. Inspect carb throttle/choke linkage for proper operation.
3. Remove carb and clean/rebuild.
Here is the link to the Kohler service manual.http://www.kohlerengines.com/onlinec.../tp_2339_d.pdf
Nemesis
Old 08-12-2011, 04:26 PM
esarvey's Avatar
esarvey esarvey is offline
Default kohler won't start
The only other thing after all the work U did, is maybe a sticking valve. good luck fixing that bad boy.
DaDuke of
DaDuke of
2145,1864,1811,1810,1541,1330,1210,1020,1641,147,1 24,73, IH FARMALL CUB. 7254, 1863, IH 982
Old 08-12-2011, 04:54 PM
This being a magneto engine, the timing cannot be changed or be off.
