Old 12-16-2011, 11:02 PM
It would, but you would have to use a CV joint driveshaft from the 1862 as well, because the input shaft on the 1862 pump is splined.
Old 12-16-2011, 11:04 PM
wally67's Avatar
wally67 wally67 is offline
Great, Thanks for the info now all I need to figure out is how to adapt the steering valve to the non tilt dash the 1811 has
Cub cadets 100, 128, 582, 1050, #2 tiller, 42" blade, 2-10" Brinly plow, 12" cat0 Brinly plow.
Old 12-17-2011, 08:35 AM
I used a 300 series Deere power steering unit when I converted my 782 to power steering and it was a relative simple swap.
It lowered the steering wheel about 1" but other than that it worked fine, without changing the shims in the pressure relief valve in the hydro.
Old 12-18-2011, 09:09 PM
wally67's Avatar
Thanks for the responses guys! George, what mounting brackets did you use to mount the steering valve at the bottom? Thanks
Old 12-19-2011, 08:54 AM
I mada a custom one from a piece of 3" "C" channel iron.
it was relatively simple or you could bend a "C" from iron
I used 2 existing bolts on the ross unit
Old 12-19-2011, 02:32 PM
inspectorudy's Avatar
Default Power steering
I am thinking of doing the same thing and was wondering if the existing steering spindle on my 1811 will be strong enough to handle the installation or would I have to get the beefed up one?
1811 Hydro
Old 12-19-2011, 06:02 PM
wally67's Avatar
Check out extreme motor works and go to his 782 front end loader project it looks like he used the stock 1811/782 front end but put the heavy duty spindle upgrade he sells on it and braced up the steering arm part of the spindle when he added power steering to it. He also sells the valve mounting brakets.
As long as you have it adjusted so the cylinder itself is limiting the travel and not the stops on the axle, it'll be fine.
