Old 05-02-2012, 02:00 PM
1811woody's Avatar
Default Super??
What is it that makes a super a super ?
Old 05-02-2012, 02:21 PM
superduty5.9's Avatar
superduty5.9 superduty5.9 is offline
The extended frame length (9" I think), 26-12-12 rear tires. I'm sure there's more. That's all I could think of right now!
1200, 1450, Red 782
Old 05-02-2012, 02:24 PM
MWShaw's Avatar
MWShaw MWShaw is offline
Dual rear brakes, front hydro ports, power steering, and the other things superduty mentioned.
Old 05-02-2012, 03:05 PM
maddog784's Avatar
Front tires are larger and the front axle is different also.
CCC 784 w/ Triple Hydraulics
IH 982
50C Deck
41" IH Rear Blade
QA42A Snowthrower
Old 05-02-2012, 03:16 PM
All the above. also a steering wheel from what I can tell off of a Cub Low Boy. It is a bit bigger than the standard GT steering wheel.
Old 05-02-2012, 04:34 PM
Talking
Unless it's a Cyclops, they have the same size steering wheel as the regular Cyclops
Old 05-02-2012, 04:39 PM
Not necessarily...those were only standard on the 1572-2072. 982-1914 had manual steering, and the 982 would not necessarily have had split brakes or front outlets, either.
Frame length, larger front and rear tires, larger front axle, and different reduction ratio in the rearend are the differences as has already been mentioned.
Old 05-02-2012, 04:52 PM
CCSuperMan's Avatar
Size ..............and size matters so they say !!
The supers accomadate a 60" deck also which I wouldn't put on a non-super (especially a HEAVY Haban) !! That's alot of deck .
Old 05-02-2012, 06:29 PM
MWShaw's Avatar
Ok, I stand corrected, I was just comparing my 782 with my 2072. I'm learning more and more everyday!
Old 05-02-2012, 10:03 PM
Dave01's Avatar
Dave01 Dave01 is offline
Matt is right (as usual!), my 2084 didn't come with front ports, I had to add them.
1864 w/48" deck, 2084 w/54" deck + 54" blade, 3204 w/48" deck
