#31
the pump on mine is the C210 as is on the "newer" 1972-1975 loaders, 128/129/149 1200/1250/1450/1650. i contacted MTD and they no longer support this pump and all i could get was an elementary cross section drawing for it. i think the difference is the flow rate but i am sure MTE could give you the exact differences. the "newer" loaders have much larger uprights than the older versions so using the old upright wont give you the volume and may not be leak tight. the pump is also mounted on the front and runs off the front PTO. the whole set up is made to be easily installed and uninstalled. you have the old/original tank so why not use it as it was configured?
Kwik-way is still in business and supports it and the loader as far as seal kits. the guy to talk to is Rick in the Parts Dept. i had to rebuild a cylinder on mine so if you ever need to rebuild one, post a message before doing so.... may save a head ache or two.
100(2) 128, 129, 76(1/2) |
#33
correct me if I'm wrong here guys but when my Father in Law traded in his model 70 on a new 682 the dealer told him the 682s frame wouldn't support a loader and that there were none available.I inherited the 682 with a blown engine and It's one of the reasons I'm here I'm repowering it now.When dad swapped in the 70 it went with the tiller,dozer blade,mowing deck,tire chains,Weight box and a Danco loader !the 682 came with a dozer blade and mowing deck. since visiting here the IHC infection hit and I bought a 70 in sad shape to restore and have since located dads now dead and rusting 70 with the loader still on and I'm trying to make a deal on it to come home.
#34
BS...the 682's frame is probably stronger than the 70's...same for the front axle and spindles. The 682 is more than capable of using a loader.
| Thread Tools | |
| Display Modes | |
