I needed a few cub steering wheels off and didnt want to fight them for days or weeks so I built this puller from some scrap steel and some hardware. It removed 4 wheels in less than 15 min with no damage to wheel or shaft. I used all flat steel for mine, but would use 2.5 in wide channel iron for the bottom piece if I was to do it again and notch off the corners for the bolts to go into the welded on nuts. The single nut is just welded on and the 2 together have the threads drilled out and act as a bushing. The hole for the column tube is drilled with a 1.5 inch metal hole saw. The top piece has 2- 3/8 holes drilled 4.25 inches apart and a 1/2 hole in the center of them with the 1/2 nut welded on. I used 3/8 threaded rod to connect the top piece to 2 nuts welded 4.25 inches apart diagonally across the top of the bottom piece. To protect the threaded shaft i took a 5/16 carriage bolt and filed the corners off so it would sit flat on the end off the shaft, I think the bolt I used is actually called a plow bolt as it is flatter and wider than a normal carriage bolt. The models I've tried it on are 100, 102, and original but it should work on others.
Great job on the steering wheel puller!
Nice job!
How bout shipping one of them over so I can get my 1200s wheel off
and then you can ship it over to my house.![]() NIK,
It dont cut grass, but its yellow. |
Well done!
| Thread Tools | |
| Display Modes | |
