Old 05-20-2010, 10:00 PM
dcdodge's Avatar
dcdodge dcdodge is offline
Default 44c Deck Help
Guys,
I've had the 682 & 44c deck since new so it has burned a few tanks of gas & I've done my share of repairs over the last 28 years.
My problem is trying to get the blade cutting height above 2.25" to something more reasonable like 3.0 - 3.25".
Is there a site that has found a good way to achieve this? Looked through some of the past threads but no luck as some of the links have been disabled.
May try to fabricate an adjustable link with an offset for the left side but the overall deck design does not seem to allow higher grass cutting heights. Have tried using a duplicate adjustable hanger like the one on the right side for a few years with reasonable results but this creates some other alignment problems.
TIA
Old 05-20-2010, 10:15 PM
murphycc
Guest
Posts: n/a
I have two adjustable hanger in mine.
Scott
Old 05-21-2010, 06:18 AM
dc:
What are you referencing....????
Old 05-21-2010, 06:30 AM
Just a suggestion, my 1200 started to mow lower and lower, I thought the linkage was worn, which it was, especially the round crossmember the step bracket is on that acts as a pivot point....but I eventualy found the culprit.. It had cracked the pin that holds the lift arm to the rockshaft and it was very slowly rotating on the shaft, allowing the deck to drop.
I replaced it and now I can lift the deck high enough to clear some of the random rocks in the yard...
Old 05-21-2010, 10:02 AM
dcdodge's Avatar
Roland,
During a search I located a thread where you inserted a link labeled "Deck".
The email was dated 04-05-2010 & sent at 07:10 AM.
Clicking on this results in a error on both of my computer systems at home & at work so I could not access the link.
Please send to me directly if this will help my situation:
petrow@jmusa.com
Thanks
Old 05-21-2010, 12:43 PM
IF you are looking for the Manual for the 44C deck, go to our Technical Library -Implement Section, and locate the thread for the 44/50C decks. Click on it and it will bring up that manual.
Old 05-21-2010, 05:00 PM
aagitch's Avatar
aagitch aagitch is offline
I know your 682 is manual lift but on my 782 all I have to do is adjust my height knob on the frame and it'll cut 3" when I lower the deck.
