Old 02-26-2015, 12:40 PM
Terry C's Avatar
Terry C Terry C is offline
Sorry I derailed this thread
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
Old 02-26-2015, 12:46 PM
red211's Avatar
red211 red211 is offline
Now this could get interesting!!
73 149, 73 109, 71 128 with sleeve hitch, decks for all with a 44C on the 149 as the daily mower. front blade and IH rock rake
Old 02-26-2015, 02:15 PM
Terry C
The gear drive rear PTO turns at around 515 RPM, and they already make an adapter to take it up to the same size as the larger 540 shaft. Not really any need to make it run faster. It's not like a 540 RPM piece of equipment has to be run at exactly 540. Why bother with a reverser anyway? Not like they make any implements that you can put on the GT. Just leave it and focus your time on making an implement that can run off the reverse direction PTO.
Old 02-26-2015, 02:38 PM
EarlJ's Avatar
EarlJ EarlJ is offline
Terry C
Bingo, that's what I have in mind, I have several small 1:1 right angle gear boxes some that turn the same direction some that reverse.. I've got a couple 1:1.5 which may also work, anyhow that's just the basis for my idea..
126 in surgery with weights, spring assist, 3 point and sleeve hitch
100 with woods finish mower and rear lift,
Nice 125 with super nice sweepster, 1782 Super Diesel,
1650,782D in surgery, 102 parts tractor..
3 Brinley plows, Brinley cultivators , rear scrape blade, front plows and custom built bedder attachment.
Old 02-26-2015, 02:49 PM
I think you better sit down with a pencil and do some math..... To run a #2 tiller off the rear PTO, your going to have to really speed things up...... You'd have to redesign the whole drive for the tiller, and you only have what, 8" between the tiller and the back of the tractor.... Not enough room for a gearbox and a driveshaft with two knuckles. Better off keeping it running off the front PTO.
Old 02-26-2015, 03:12 PM
Terry C's Avatar
Terry C
This is like the chicken or the egg question, implements or the way to use them.
What I had in mind for this box was that it would have the same outside look as the rear cover plate, just like it just thicker. With a pulley out the side and a 540 type shaft coming ou the rear.
I wanted to make a three point sickle mower to use.
I don't like the box that I have seen with the pulley on the side, it seems added on.
I know it's silly cause there is easier ways to do this but I have a vision..
Terry
Terry
3225
Old 02-26-2015, 03:23 PM
Terry C's Avatar
Even if I dont reverse and never be able to use the shaft out the back it will look cooler than the boxes that I have seen
Terry
Terry
3225
Old 02-26-2015, 03:24 PM
If you say so.....
What I had in mind for this box was that it would have the same outside look as the rear cover plate, just like it just thicker. With a pulley out the side and a 540 type shaft coming out the rear.
Unless you have a big stack of money to burn...... I don't think you will find this feasible. Have you ever priced having a gear made? And you can't make them out of cast iron. Gears have to be made of steel.
Under edit: I see you run a CNC. Still.... have you ever made a gear?
Sickle mowers don't care which way you turn the input shaft. They work no matter what. No need to build anything but a driveshaft. You are really making this more complicated than it is.
Old 02-26-2015, 03:30 PM
Terry C's Avatar
I don't run a Cnc. I hire people to run mine.
I also have made thousands of gears.
Terry
3225
Old 02-26-2015, 03:40 PM
Ok. Well, if you do make one, post some pics!
