Old 02-26-2015, 01:12 AM
EarlJ's Avatar
EarlJ EarlJ is offline
Default Check out what I scored...
I got this complete for a heck of a price. I plan to clean it up and drop it in the 126 that has yet to be completed. I know there isn't much it can be used for but I'm a country engineer and have an idea on how to make a #1 or #2tiller runn off of it. I'll update when I get it working...
126 in surgery with weights, spring assist, 3 point and sleeve hitch
100 with woods finish mower and rear lift,
Nice 125 with super nice sweepster, 1782 Super Diesel,
1650,782D in surgery, 102 parts tractor..
3 Brinley plows, Brinley cultivators , rear scrape blade, front plows and custom built bedder attachment.
Old 02-26-2015, 08:20 AM
Congrats, another plus to using that rear end is the internal brakes which I prefer to the external.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 02-26-2015, 08:34 AM
sawdustdad's Avatar
I'm jealous. I want a rear PTO so bad. Seem to be so scarce...
Old 02-26-2015, 09:39 AM
DoubleO7's Avatar
DoubleO7 DoubleO7 is offline
Are you sayin your gonna try and run the tiller via the rear pto shaft?
Old 02-26-2015, 10:05 AM
Terry C's Avatar
Terry C Terry C is offline
I for one would like to see some implements that run off the rear pto. From what I have read there is few, and the hold up it the direction it turns?
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
Old 02-26-2015, 10:56 AM
DoubleO7's Avatar
and the speed
Old 02-26-2015, 11:18 AM
fleetlines's Avatar
fleetlines fleetlines is offline
Very nice. Lucky you. They made a reverser. Just thinking ... I don't know how hard it would be to make a reverser but if you could, you could use gear size to set the speed. I hope to see what you come up with. Congratulations.
Original, Serial #44578, K161S Serial #659144, 3pt. w/ Spring Assist, Deck, Fenders, Lights
72, Serial #231093, K161S Serial #C281773, 36" deck
149 & Original Yard art
1650, Serial #2050067U559932*, K341 Serial #7133367, 3 pt. hitch
1650, Serial #2050670U601762*, K341 Serial #7584702 SIM cab, 50" deck, tires loaded & weighted
123 FEL and weight box
10" & 12" Brinley Plow, Decks, Roller, Cart, Power angle blade, dozer blade, Snow Thrower, Airator, Tiller
Old 02-26-2015, 11:24 AM
Terry C's Avatar
So we need a gear reduction reversing box then.
I'll start on one.
I'd really rather have one that uses a shaft like a big tractor( like540)
What ratio?
But if I made one to drive a pulley in approximately the same place as the belt driven one it would work right.
I'm not just talking here I have the means to do this(Cnc machines water jet
gear hobbers ect)
Terry
Terry
3225
Old 02-26-2015, 11:29 AM
PaulF PaulF is offline
gear hobbers ect)
Impressive, I'm eager to see what becomes of this!
Paul F
Infantry Veteran
Original...100/123/147 custom...149 FEL...782D...1282...1864...2182G
Old 02-26-2015, 11:37 AM
Terry C's Avatar
The local foundry owes me a favor too so, machine the first one out of solid then try it, have some castings made so the box will look factory.
I'm off to the local cub collector to get a box and tiller.
Terry
Terry
3225
