Old 12-06-2015, 07:01 PM
ford4150's Avatar
ford4150 ford4150 is offline
"Questions:
How many wires running to the coil, what color, and where do the go? If I'm not mistaken, should be 2. One from the stator, and one that goes to the points. The condenser should also attach to the point wire.
This motor doesn't use a rectifier correct? Wire runs straight from the stator to the coil?"
There is one wire on the coil, yellow in earlier photo.
4 wires from stator. red and yellow are for lighting, black connects to yellow coil wire, green is ground.
No rectifier in the wire from the stator to the coil. There is a rectifier/regulator in the lighting circuit to keep from over-voltage the 6V light bulbs.
Sorry, I don't know how to separate questions and answers as you do.
Old 12-06-2015, 07:51 PM
I've got to entertain some guests for a while. I'll be back later with some direction...... hopefully.
Old 12-06-2015, 08:12 PM
ford4150's Avatar
I'm probably done for the night also.
Old 12-07-2015, 12:26 AM
Soooo.... this ignition system is like nothing I've ever seen on a Honda. Now, that said, I've never played with the mo-peds.
This is an A/C ignition system. It functions much differently that any other because of using A/C current.
The wire that comes to the coil from the stator is also the signal wire from the points. The points simply ground out the wire when they close, and when open, it lets the current go to the coil. (Electricity always follows the path of least resistance.) I cannot find any info on the voltage that the A/C generator puts out, but can tell you that you will not have any luck testing with a test light. My suggestion is finding out how much A/C voltage that is supplied to the coil for spark, setting the points open all the way so that they cannot close, and spin the engine and see if it is making power. Then test further from there. My guess at this point is that the winding responsible for power to the coil in the stator is bad/open. There are 3 windings in the stator. 1 for the ignition, and 2 for all other power sources. Depending on year, the voltage fed to the coil may or may not be direct fed. On some models it feeds through a silicone rectifier before going to the coil. Near as I can tell, this is just to feed extra voltage to the ignition coil, from the other two stator windings, during low voltage situations. (I.E. starting and sitting idling with all the lights on.)
I suggest you find a book or PDF of how to do a component test. I found a PDF of the supposed Honda manual for that machine, but outside of tear-down and assembly, it was vague at best.
Holler at me if I can help.
Old 12-07-2015, 08:18 AM
The early 2 smoke single Yamaha's '68-'72 used an AC system like that.
they put out 135-150 V. to supply the ign system,-- if that helps.
look closely @ your source coil for the Ign.
Old 12-06-2015, 07:52 PM
twoton twoton is offline
Click the multi quote icon (its the one to the right of the quote icon at the bottom right of each post, I think (occasionally)) and then edit the quote and add your response.
Old 12-06-2015, 08:10 PM
ford4150's Avatar
Thanks twoton!
Old 12-07-2015, 09:37 AM
Billy-O's Avatar
Billy-O Billy-O is online now
I do not understand. To me, the schematic clearly shows the wire from the stator intersecting the silicon rectifier on the way to coil. Care to enlighten me? There's Black/Yellow wire leading to rectifier and from rectifier it's Black/White wire that loops around the stator (in sketch) to the coil.
I thought this images without the colorful gobbygook wires might be easier to see here. Maybe/maybe not:
Plow blade
#2 Cart
QA36 snowthower
Old 12-07-2015, 09:50 AM
Attachment 70288
In the Honda manual, there are about 25 different diagrams. Depending on what year, or model there are different diagrams. His cycle may or may not have the rectifier. Also, if you look, the ign coil is not fed off the output of the rectifier. It is fed off of one side, the voltage of that side does not go through the rectifier, so it would still be A/C voltage.
Old 12-07-2015, 10:40 AM
ford4150's Avatar
"My guess at this point is that the winding responsible for power to the coil in the stator is bad/open."
I agree with this.
Since new stators are NLA and used ones on eBay are outrageously priced, without a guarantee, I'm going to convert to a CDI ignition.
Thanks to all for your time and effort.
