Old 12-20-2015, 07:05 PM
This is my idea of a generator. Power goes off (like it does regularly with AEP) this fires up and life is good.
Old 12-20-2015, 07:07 PM
twoton twoton is offline
That's great, automatic generator and pool in the background. Life is good.
Old 12-20-2015, 09:56 PM
jaynjeep's Avatar
jaynjeep jaynjeep is offline
Leave it to Sam to have the "cats meow" of all generators!!
Jay
Proud owner of the following:
Old 12-22-2015, 07:31 PM
Anyone know if this mule drive will fit a quietline? May be the start to my project.
http://www.ebay.com/itm/Cub-Cadet-68...UAAOSwstxVCF1y
Old 12-22-2015, 08:43 PM
It will work for what you want it for.
Old 12-23-2015, 01:10 AM
OldSkull's Avatar
OldSkull OldSkull is offline
Most cheap Chinese made generator/alternator produce crappy 60Hz sinusoidal wave at 3600 rpm (Oscilloscope test reading..), you better get a Japanese or old American made unit.
Using the old K series Kohler of a QL is another questionable choice, efficiencies is not their "Forté", most modern OHV engine do a lot better but since you need to use what's available as cheap has possible, you can probably power your alt/gen with the 16hp running at 1800rpm using a 1 for 2 ratio, this way you save a bit on gas and you cut the noise a bit too.
Gilles.
1963 100 (red)/in storage
Old 12-23-2015, 05:42 AM
Thanks Jon.
Thanks OldSkull, I appreciate the tru sine wave stuff and all that, never really wanted to get one of those HF jobbers. Had the same idea about the 2 to 1 ratio and lower rpm, maybe smaller wattage gen head, something to just run a saw and drill or some thing like that.
Thanks guys, and Merry Christmas.
Old 12-23-2015, 08:11 AM
Things to ponder:
The kool factor of building a accessory to go on your tractor is very rewarding.
sometimes it is practical sometimes not.
Being older now, I tend to not fuss as much as I once did.
It takes a bit to install/remove the power generator on the front of a tractor
after you have it finished,
much like a snow thrower/blower.
I wonder if a 2 to 1 ratio is practical?? sounds like a lot to expect of an engine unless the generator head is designed to run @ 1800.
Today I see a lot of generator sets sell quite inexpensively @ auctions C/ list
& local papers. $150-$250
I would think it less expensive/easier to obtain a stand alone unit that can be pulled or set in a cart behind the tractor.
or even on a rear mounted " carryall"
That would free up the tractor to go-fer things/tools etc.
Just some thoughts, not to rain on your parade.
Old 12-23-2015, 05:15 PM
Yes sir ol'George, you are right there with some good points. Thanks for your thoughts. And Merry Christmas!
Old 12-23-2015, 05:38 PM
OldSkull's Avatar
Things to ponder:
George a 1800rpm generator is a 4 poles unit and they cost a leg+a arm but I'm sure your already know it so I cut the crap and just let's call those 3600rpm unit "Standard head unit", most companies build them to produce a constant 500W per HP since 1hp=745.7 watts we have a safe margin.
I think the 16hp of the 1650 got enough torque to power a 4 to 5Kw gen
head at 1800rpm using a 1 to 2 ratio pulley but there is no way this setup can be efficient or practical like a stand alone unit.
(Test need to be done first so I speculate here)
This is just a fun project you can rely on in a emergency case or just to power some outdoor stuff for a short period of time, a cheap "Life saver" if you prefer.
Oups...Almost forget! Merry Christmas all !
Gilles.
