Old 05-05-2017, 12:53 PM
dbuck dbuck is offline
Smile Grease zerks
What is the best way to remove pressed in grease zerks? These zerks are pressed in the spindle shafts on my 54'' deck. Thank you for your time.
Old 05-05-2017, 01:07 PM
If they are pressed in and working, why do they need removed?
Old 05-05-2017, 03:08 PM
Shrewcub's Avatar
Shrewcub Shrewcub is offline
That's what I was thinking.
Buy a cheap coupler for your gun, like my uncle did, and they just pull right out when you're done greasing.
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1980 IH Cub Cadet 782 w/CH20
1966 IH Cub Cadet 102 w/K301
1961 IH Cub Cadet O
1967 IH Cub Cadet 102 & 122
JD 2155 w/ 175 loader
Old 05-05-2017, 05:28 PM
What Travis says is true especially if the gun builds up pressure and it won't take grease and you try to remove the gun.
I'd say if you just want/need to change them, grab/clamp them vertically with a set of vice grips and twist and pull and they will come out. Then run a 1/4 x28 tap in the hole and put new fitting in
Old 05-06-2017, 09:56 AM
Smile
Thank you Fellows for the replies. J-Mech, I need to remove them in order to press the pulleys off the spindle shaft.
Old 05-06-2017, 12:03 PM
Well,
you could use a deep well 7/16",3/8 drive socket to push on, and leave the
"nipple" in the shaft
Old 05-06-2017, 02:40 PM
Well,
That's what I was going to say.... put a socket on top of the shaft. George, we think so much alike.....
Old 05-06-2017, 10:02 PM
Hmmmm
don't know if that is good or bad? Ha,LOL!
Old 05-07-2017, 08:36 AM
Smile
Thank you for the great idea Fellows. I will do it that way. In my old age I think I burnt up all the smart brain cells now I am working on the dumb ones.
