But if you must tear it apart to look around (which sounds like something I would do, but mostly because I like to see things with my eyes and not assume based on tests), if they're the metal type you can probably get away with it, maybe. If they're the graphite kind, forget it. They aren't coming off in one piece. |
My concern is the fact that the tins have been pulled off the one side and the head bolts look one they have old tool marks on them, for all I know someone has had the head off and there isn't even a gasket. Since this thing has been sitting forever and nobody has heard it run I would just like to know as much about the engines condition as possible before I even attempt to fire it.
can't hurt anything really. Turn the driveshaft over with the plugs out by hand, and if no stoppages then try it with the starter and feel if you have compression. if so, then check for spark, if so, then squirt gas in the carb and see if it will run and go from there. you are testing it. if it appears to be ok then you can spend $25 on head gaskets and clean the carbon and look @ the valves and the bore to see if anything drastic is present.
I still wouldn't pull a head just because. I like what George just said. |
| Thread Tools | |
| Display Modes | |
