Old 05-07-2017, 09:08 PM
Default Temporarily reusing head gaskets.
I'm sure this will spark a lively debate. Later in the week I plan to start tinkering with this 784, I would really like to pull the heads to inspect the cylinders before I even try firing it but I want to spend as little money as possible getting it to run to see if it's worth putting money into. My plan is to temporarily reuse the gaskets provided they're still in one piece, I will clean them and use some copper spray. If it runs and isn't a smoking, knocking pile of junk the gaskets will get replaced immediately. Your thoughts?
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 05-07-2017, 09:11 PM
To further add to the head gaskets debate I will ask if I should use Kohler gaskets or aftermarket? I generally like to use genuine Kohler gaskets but I know for a fact they are graphite with no fire ring, I see some aftermarket gaskets on eBay that have a fire ring and are about half the money. Opinions?
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 05-07-2017, 09:21 PM
Go ahead nothing to loose, I'd do it for what you are wanting to do.
you've got a 50-50 chance of old ones working in the long run,
if they are the fire ring ones.
The others usually ruin when you remove them.
These work well on several engines I have.
Ebay: 271824562906
Old 05-07-2017, 09:25 PM
I've done it and gotten away with it.
Old 05-07-2017, 10:10 PM
RLause's Avatar
RLause RLause is offline
I've done it more years than I can remember.
Richard
Old 05-07-2017, 10:31 PM
Terry C's Avatar
Terry C Terry C is offline
Instigator!
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
Old 05-07-2017, 10:40 PM
DieselDoctor's Avatar
Go for it, I've done it. For what you're planning to do, it's only short term anyway.
Old 05-07-2017, 10:52 PM
Billy-O's Avatar
Billy-O Billy-O is offline
I've had some luck....but won't preach it.
Plow blade
#2 Cart
QA36 snowthower
Old 05-08-2017, 12:18 AM
cubby102's Avatar
cubby102 cubby102 is offline
I've done it multipul times. I got a couple engines that I never got around to putting new one's on that are running fine. But to do in a pinch it'll work fine
Old 05-08-2017, 01:13 AM
If you really want to save money, pull the spark plugs and look in the hole. Roll the engine by hand to satisfy yourself it will roll. Then get it running. Just leave the heads on it. Why do you need to see the cylinders to try and get it running. It's either going to run or not. Pulling the head just to look isn't going to change anything. If your only going at it to look..... it's a waste of time.
