Old 04-05-2018, 09:30 PM
farmall fred's Avatar
farmall fred farmall fred is offline
Here is a link to a Wikipedia article on plastic welding. It explains the different methods available. You might also check to see if a manual for your unit. Big thing is using the proper plastic rod to match the type of plastic you are trying to weld.
Good luck with your repair.
Tom
https://en.wikipedia.org/wiki/Plastic_welding
Old 04-06-2018, 12:43 AM
brudder brudder is offline
I've also seen people use something called Plast-aid to repair the cyclops plastic. I used some myself and think it's amazing stuff. Kind of spendy but seems superior to epoxy. You could fix that bracket up nicely.
It's a two part system. When you mix the two parts, it starts out runny, then gradually gets thicker. Sets up rock hard in about 10 minutes.
My only concern is that it could be brittle, but I have no negative experience to back that up, just observations of the stuff after its cured.
Old 05-31-2018, 07:52 AM
mach1's Avatar
mach1 mach1 is offline
Im melting stainless mesh into it to add strength.
Old 05-31-2018, 08:00 AM
mach1's Avatar
Pictures after plastic weld complete. I will add JB weld for extra strength and touch up with some bondo.
Old 05-31-2018, 10:26 PM
The repair looks pretty good. I would not have an issue using the grill after it is finished. You can save the NOS one for down the road if this one fails again. Good luck in getting it to run again.
Old 06-28-2018, 11:14 AM
mach1's Avatar
Default Grill is done
Here is the competed grill restoration. I used insulators tape for the reflective aluminum in the light area. I think it turned out pretty good and it feel strong.
Old 06-28-2018, 11:23 AM
cooperino's Avatar
Very nicely done! Plastic is a pain in the ass, tedious to work with, etc. But that looks like a fine job there. Nice going!
Old 06-28-2018, 11:37 AM
Dirty Steve's Avatar
Your repair looks very good! But as Fred said, get a brand new one and save it for the future!
Old 06-28-2018, 12:57 PM
Great job on the repair!
Old 06-28-2018, 01:02 PM
bllwnkl's Avatar
bllwnkl bllwnkl is offline
Nice repair! Hope it lasts a while.
Randy
