Old 03-29-2020, 11:39 AM
On second look at the picture, it appears someone has already "fixed" it at some point.
Old 03-29-2020, 10:29 PM
IHCubCadet147's Avatar
I was thinking the same thing, the welds don’t look factory. Both sides are like that.
Old 03-31-2020, 08:57 PM
I glued it tonight. I’ll take the clamps off and paint it tomorrow.
File Type: jpg ADA30C2E-F168-4799-BDBE-8D50FDB5363E.jpg (11.4 KB, 66 views)
Old 04-01-2020, 07:51 AM
I hope it works out for you but I have my doubts.
Old 04-01-2020, 08:49 AM
cooperino's Avatar
Seems like a decent repair. Not sure of longevity of it.
I was under the assumption that you wanted a repair that could be done avoiding paint work. After this repair, you said your going to paint it. My question is, if you planned on painting anyway, why not just use a welding method to permanently repair? Someone mentioned thicker gauge steel. Paired with that and welding it in then painting i think would have been a truly permanent solution.
Your time, money, tractor of course. Just curious.
Old 04-01-2020, 09:17 AM
We’ll see. The glue I used is pretty good, it’s meant for holding body panels on cars.
I am just going to touch up that spot on the inside. I didn’t want to paint the outside of the hood.
Old 04-01-2020, 09:19 AM
cubs-n-bxrs's Avatar
I wouldn't give a glue job a prayers chance. I don't think the glue will hold up to the vibration the hood is exposed to. Spot welding or tack welding is the only real fix.
Old 04-01-2020, 09:28 AM
ironman's Avatar
ironman ironman is offline
Go visit a body shop, you'll be in for a surprise.
Old 04-01-2020, 10:43 AM
cooperino's Avatar
Ah... understood
Old 04-01-2020, 11:21 AM
guido guido is offline
Looks good.
I have used Pliobond in the past with some success on other projects. Not sure it would hold up to the Kohler shake though. My "olde dad" told me they used it when patching the fuselage on their B-17's.
Alan
Basket Cases: 129, 1450 sold, 1650
125: 48" Mower Deck, Windbreaker Cab
127: 3 turn steering gear, Spring Assist, Sleeve Hitch, 48" Mower Deck, Dozer Blade
147: 3 turn steering gear, Spring Assist, QA36a w/Xtreme Motorworks Wings
