Old 03-28-2020, 10:32 AM
IHCubCadet147's Avatar
Default How would you fix this?
The hood brace on my 125 broke. I know the right way to fix it would be to weld it, but I don’t want to burn the paint off the outside of the hood. Any other ideas what I can do? I thought about an epoxy like JB Weld, but I don’t think it would hold up too long.
File Type: jpg E4923B7B-FF19-4567-8FF1-C44F42274D1F.jpg (11.8 KB, 250 views)
Old 03-28-2020, 01:10 PM
cooperino's Avatar
I own a spot welder. Some of the better rental places will rent them. If you can rent one it would leave the smallest amount of damage.
Old 03-28-2020, 02:30 PM
Make a new one from a thicker gage mat'l
I have done it on several Cubs
Use a spot weld cutter to remove what's left of the old one from the inside.
Old 03-28-2020, 06:28 PM
Flex seal the sucker on, yeeeeee haaaaaa.
Up to 534 and counting...
Old 03-28-2020, 07:50 PM
The JB Weld fix will work,, ya just gotta do it right,,
Bend a piece of thick siding or other sheetmetal to an "L" shape,, some piece of metal close to the thickness of the hood.
If you can not find that, a thin piece of angle steel, with legs that are at least one inch can be substituted.
you must have at least 4 square inches of area that will contact EACH part.
Bend it until you have a good fit,, apply the JB Weld to the at least 8 square inches of contact area.
I would apply it to all 4 surfaces, prior to assembly, to insure no spot remains "dry"
After curing, that lap joint fix will be easily as strong as the previous tack welds.
Large lap joints do very well at resisting vibration,,
I have fixed many things that normally are considered "weld only" using the large surface area trick.
Old 03-28-2020, 08:34 PM
We have one, but that would be the last resort.
Great idea, I’m going to try it.
Old 03-28-2020, 08:49 PM
Riley Henderson's Avatar
Riley Henderson Riley Henderson is offline
Keep us informed what works I have a 122 with the same problem curious to see the results
Best of luck on the repair.
IH cub cadets 800x3,1000,1100,1200x2,1250DS,1450,1650DS, 71,122x2,123, 73x2,106,107,126x3,127,147x2,86x3,128,149, 169x2 ,Original, cadet 55, to name a few
CCC machines
1282,1050,2072,1535,1440
Old 03-28-2020, 09:01 PM
Will do.
Old 03-29-2020, 09:12 AM
jbrewer's Avatar
jbrewer jbrewer is offline
I think that piece has completely fallen off my 122. :-)
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
It's only original ONCE!
Old 03-29-2020, 09:38 AM
john hall's Avatar
Its missing on my Dad's 100. Been thinking about bending a new one and epoxying it in place. We had to run some cosmetic grooves in some large stainless sheet metal strips at work. These were glued/epoxied in place in the entry of a hospital, some were even overhead. There are some rather high tech "glues" on the market these days. Maybe somewhere like McMaster carries such.
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
