Old 09-09-2011, 10:27 PM
dieselmax dieselmax is offline
Default Is there such a thing as a BB42 snow thrower?
Went to look at a snowthrower today and from search online it looks like a BB36 but measures 42 it came off a 582 how good are they and will it fit my 1914
Tia
Old 09-09-2011, 10:53 PM
maddog784's Avatar
It sounds like it's a QA-42 model - it may be adjustable. The BB-36 was a bolt on; it did not have a quick attach.
Pictures always help - if I don't ask, someone will .
Nate
CCC 784 w/ Triple Hydraulics
IH 982
50C Deck
41" IH Rear Blade
QA42A Snowthrower
Old 09-09-2011, 10:58 PM
i'm kicking myself for not getting any pics but it has the cable for the chute rotate and a quick connect that is not adjustable
Old 09-09-2011, 11:03 PM
Several things are not adding up here...there is no BB42, the nearest thing to that would be a CC42, which would not fit a 582 anyway. A picture is worth a thousand words here, but at any rate, it doesn't matter because it's not going to fit your 1914 anyway. You need a 450 or 364 (or H48).
Old 09-09-2011, 11:25 PM
Ok after searching more, I think it's a Haban H-42. Anyone have info on these? Thanks for the quick replies
Old 09-10-2011, 08:03 AM
Most of the parts are NLA, and it's too small for your 1914. In my previous post, I told you which models will work.
Old 09-10-2011, 09:06 AM
but would it mount on my tractor as snow blowers around here are few and far between
Old 09-10-2011, 09:25 AM
I suppose one could make a Haban H-42 fit with the right amount of fabrication. The H-42 was designed for 482-782 Series of GT Cubs. The H-48 was designed for the SGT 982, 19xx Series of supers.
Click on this link for more information..... Haban
Old 09-10-2011, 10:00 AM
thanks for all the info am gonna pass on the snow thrower and keep looking for the right one
Old 09-10-2011, 10:16 AM
Iowa Farmboy Iowa Farmboy is offline
I really have to question why the Haban 42 wouldn't work. As a 582 and a Super are both wide frames. The only problem that I might see is not being able to lower it to the ground all the way. 42 inches will cover the tires track on a super it won't give you much room but is possible.
Josh
1989 SGT 2072 (restored)
60"Haban Deck, 54 "Haban Blade, 48" Cub Cadet Tiller, 12" Brinly Cat O plow, 48" Cat O landscape rake
Cub 128 with creeper and rear PTO with reverser(next project)
IH built 682 and 782 that will combine to make one
