Old 11-08-2011, 06:12 PM
Rob M Rob M is offline
Default 1872 front axle bushings
Looking for axle bushings 941-3005 for the 1872, 2072 tractors. I see they are NLA. Anyone have dimensions for them as I can make them at work. I just can't have the tractor down right now to remove and measure. Also, are they made out of brass or bronze? Mine have a lot of side play in them and I assume thats not normal. The tractor has 860 hours on it and I've always greased them monthly. Thanks.
Old 11-08-2011, 10:45 PM
cub1450's Avatar
cub1450 cub1450 is offline
Could you post a pic of what you are talking about .The 1872 is supposed to have bearings in the axle tubes not bushings I know the original had them but thats about it.
Jed
1975 1650SGT Work In Progress
1974 108 (Mint) #510358
Old 11-08-2011, 10:53 PM
What did you grease??
Old 11-09-2011, 05:03 AM
Not the wheel bearings, cub calls it steering knuckle assembly. Sorry for the confusion.
Old 11-09-2011, 05:49 AM
Again, pictures would be most helpful...
Old 11-09-2011, 08:22 AM
I think he means the bushing where the spindle goes through the cast iron axle and rotates for steering.
If mine were worn, I would measure MINE before machining, to compensate for wear.
Old 11-09-2011, 09:26 AM
riesedesperado6170's Avatar
riesedesperado6170 riesedesperado6170 is offline
You can get them though a local bearing place. I got mine at Buffalo Bearing. They are brass with a steel outer casing and the a split. There are two a side. I don't remember the exact size. I'll look and see if I find a old one, then I can measure and show you what they look like.
Old 11-09-2011, 05:44 PM
Number 2 in picture. Part# 941-3005.
Old 11-09-2011, 08:36 PM
Rob that should help a lot!
I've edited your post and changed the title to front axle to clear things up a bit.
Old 11-14-2011, 01:53 PM
CCSuperMan's Avatar
I've got a set here along with the whole axle !!
I could either part 'em out or measure and make them . Either or .
