Any one seen this type of lift arm on a blade? I've looked at tons of pictures and haven't run across one that looks like this. I'm making my own plow mount since I can't find one without a blade for less that a c note. Is it for a "float" type blade?
Scott |
I think that"s for an 82 series tractor. I have 1 just like it.
Ok, so since I'm making my own mount it should work on my narrow frame?
Scott |
It is for 82 series. I just picked up a 42" from a 682. I think the slot is for when you push dirt it won't bend the lift rod.
Clay |
That's not an 82 series bracket. It looks similar, but someone made that one.
Here's mine WAY DIFFERENT
Clay |
Mine just has a hole, no slot.
DSC_0083638x640.jpg Duke isn't the only one to get a "Monday" IH decal!! ![]() I would think the slot would be nice on a hydraulic lift. What would be the advantage of a slot on a manual lift?? |
It all depends on how you look at it. From the front seat or in front of the tractor! There is supposed to be 2 holes to lock the lift arm with a flat plate. I'm not sure if mine has it or not but have seen them with the locking plate. Also it's a 5/8 rod not a 1/2 rod.
So this one is stock?
The two holes are for a lock plate? What is the purpose of the slot?
Clay |
