Hello All,
I removed the engine in my 149 to replace a faulty governror.I noticed that the timing marks on the cam and crank did not line up, they were about 3 teeth off. The engine ran fine except for the governor issue. Should I put it back the way I found it or align it back up by the book? thanks Rick |
Rick, are you sure you've properly identified the timing marks? It shouldn't be possible for an engine to run well with the timing that far off.
