Old 12-05-2011, 08:05 AM
Thanks for the pics of the installation. It looks really good.
Old 12-05-2011, 08:16 AM
cub123's Avatar
cub123 cub123 is offline
It looks awesome! Can't wait to get one myself!
Old 12-05-2011, 01:12 PM
thenrie's Avatar
thenrie thenrie is offline
Now we need some pics of it in use!
Tony
Stafford, VA
1650, 682...
Old 12-05-2011, 07:22 PM
dsmithjr's Avatar
dsmithjr dsmithjr is offline
Well it rained all day here so no chance to try out the lift : (
Don Smith
Old 12-08-2011, 07:47 AM
rrager rrager is offline
What is the lift capacity of a Cat 0 on these super cubs? I've been toying with this idea some myself and haven't seen where anyone has said the lift capacity or the distance of travel of the lower arms. Any help would be appreciated.
Thanks,
Ross
1991 Cub 2082 - 24hp Honda repower w/ 60" Haban deck. It's been begging me to learn how to plow the every expanding garden.
1984 Troy-Bilt 8hp Professional Horse PTO with fewer hours than my wifes new hair drier. Also came with PTO chipper/shredder.
Old 12-09-2011, 04:02 AM
dsmithjr's Avatar
I don't know the capacity of the 2284 but a cat 0 hitch was a factory option so I'm assuming its capable of handling cat 0 implements. I think MattG posted on another thread the weight limits on each type of lift. Ill measure the travel I have but I can say for sure if you order the multi configuration hitch travel will not be an issue. There are so many position holes its a little confusing at first.As soon as the weather breaks ill try out my plow and blade and post some pics.
Don Smith
Old 12-19-2011, 08:59 PM
dsmithjr's Avatar
Default Trying to get the lift set up correctly
I finally got a few minutes to play with the lift tonight. My big issue now is down pressure. I wanted to have some down force but the way it is now I have 0%. Can someone with a 3pt tell me if they have down pressure? I don't know if its the way I have it set up or if it is the way the float slot is cut into the lift doesn't allow for any down force. I emailed Aaron at Xtreme so maybe Ill be able to figure it out.
Don Smith
Old 12-19-2011, 10:11 PM
My 1872 with OEM 3 point can lift the back wheels off the ground!!
Old 12-20-2011, 08:29 AM
dsmithjr's Avatar
Well I talked with Aaron at Xtreme and he told me his kits were based on the OEM lifts and they had a long float slot. He was kind enough to give me several options to get the down force I want. Finally he sold me a prototype slot float block he is working on that will give me the option for float or downforce. CADplans if your lift arm is OEM would you post a picture of your rear slot on your lift. More kudos to Xtreme Aaron answered quickly gave me info and options and didnt try to sell me anything until I asked first.
Don Smith
Old 12-20-2011, 08:42 AM
"CADplans if your lift arm is OEM would you post a picture of your rear slot on your lift"
The only "float" in my lift is in the vertical connectors that connect to the lift arms.
I am referring to shiny area on the vertical connecting link.
