For those of you who have this model or the 42", I need a couple of measurments. I bought mine without the chute control rod (the long rod with handle that turns the chute) and the rod gaurd (the small rod coming up from the side of the thrower that has a small eye-let bent in the end for the chute control rod to go through) I'm looking for the total length of the long rod from the coupling to the handle and the total length of the small rod from end to end. The small rod should pull out from its slot to get a total length or just eyeball it. Also the inside diameter of the eye-let would be great. I have bought the 3/8" rod and a new u-joint and plan to make my own with a improved handle. Will post pictures as soon as completed. Thanks for any help with these measurments.
Red 782 w/dual hydraulics & Ags. Power angle snow blade, QA 36A snow thrower, rear IH blade, tiller, #2 trailer, mower, custom made winter cab and brinly plow. |
The length of the handle is 32.5 inches from the end of the rod to the front of the handle. As far as the chute angle rod holder, it is 17 - 18 inches long. As the owner of a 782 and a QA-42A, I will tell you that the factory rod holder will touch the sheet metal on your 782. I would recommend making a custom eyelet for your combination - that's what I'm planning to do.
CCC 784 w/ Triple Hydraulics IH 982 Cub Cadet Commercial H1748 Walk-Behind 50C Deck 42" Hydraulic Angle Front Blade 41" IH Rear Blade QA42A Snowthrower |
Thanks for the measurments and the heads-up on the rod holder . Can you tell me the size of hole the use for the eye-let on the rod holder. Is it a tight fit or loose?
It is a loose fit - about 1" ID.
The pictures of the chute control rod are show and posted by bsyprit (sp) in my thread about the restoration of a QA42. Hope that helps. I think I will try to make a custom handle from some 3/8 o.d. stainless tubing.
I will try to take a picture of the rod (holder and the eye dimensions too. Regards, Chris
Casbohm Maple and Honey www.mapleandhoney.com Cubs: 147R and the "train", 127 elec lift, 127, 125, 106, 102, 100, 86, 73, Brinly plow, Snow thrower, 2 Rototillers, several mower decks and several snow plows, #1 cart, Grandkids barrel cart. |
Matt is correct that is a slightly different set up than a narrow frame.
Regards, Chris
