Old 12-08-2011, 09:26 AM
happyhab happyhab is offline
Default Original Rubber Dash Grommet
Can anyone help me out with the actual true dimensions of the rubber grommet that goes around the steering column? Trying to source one locally here in Canada.
The closest that I've found is:
1-1/2" ID
3/32" width of groove (dash is more like 1/16" I think)
2" groove dia.
2-3/8" OD
3/8" overall thickness
Thanks.
Old 12-08-2011, 04:53 PM
You really have no choice but ordering one from a sponsor. I went though this a couple years ago...that grommet is a weird size that you can't get anywhere but through CC, to my knowledge. I did a fairly extensive search and turned up nothing.
Old 02-07-2012, 09:51 AM
ihcpartsman ihcpartsman is offline
The grommet you need is part number 376254R1 and is readily available from any CaseIH agricultural dealer. There still are parts with commonality between AG and Lawn & Garden that are still available.
I am the parts manager for a CaseIH Dealer, so I usually check the numbers there to see whats available before moving on to other sources.
Hope this helps.
B
