I have suffered 30 years of peer pressure!!
My 2 best friends have WH and Gravely machines. They claim the blade that attaches to the rear axle pushes better than the front frame mount of IH and John Deere. I have a 48" blade that I acquired in a purchase that I may have to try on a Cub Cadet. D7K_1009494x800.jpg Has anyone ever tried a rear axle mount blade as compared to a front frame mount? ![]() |
ive got a wheel horse B80 that has one of those blades and have always been curious to try it because i heard the same thing.
Nick. ![]() Cub cadets 100, 125, 86, 108, 109, 128, 129, 129, 149, 149, 169, 1450, 1650 and a handfull of parts tractors. #40 box blade, ih back blade, rear ih rock rake, #2 cart, windbreaker soft cabs, windbreaker hard cab, cozy cab, kwikway loader , wards corn planter, brinly plows, culitvator, rear blade, disc and the usual decks, snowblowers and 2 tillers |
I had a Wheel Horse that pushed from the rear axel. It could move the snow. I wish I would have of kept it and tried to mount it to my 1450. I think the push from the rear axel is the way to go. I should also add that you could change the angle from the seat. It was an awsome plow. I know I am going to miss that feature. I'd like to find another one and try to make it fit.
My in-law's have a Kubota with a factory blade that attaches to the rear, Its a good strong blade but it definitely is different from the front mount blades. I used this a lot before i got my own tractors. After using the Cub front blade i have never even hooked the the blade back up on the Kubota. I just Drive the Cub over to their house and use it. Now i have only used these blades to push snow. But having used both i would take the front mount anyday. But this is just my
Diz Jr.
What differences did you see or like from the front push vs rear push? This is my 1st front push, my others were rear push wheel horses. |
![]() Quote:
149,682,1641,1711 with a 12hp in it 1 8" brinly plow 1 10" brinly plow 451 snow blower,H-48 International snow thrower 42" york rake with fold down grader blade. |
![]() Quote:
One of the recommendations when looking at a used Cub Cadet I have seen on OCC is to take a 9/16" wrench along to check the 6 bolts holding the transmission to the frame. Those 6 bolts are the "fail point" when overloading a frame of a Cub Cadet. One of the things I am trying to resolve is the overloading of those 6 bolts. ![]() Plus peer pressure!! LOL |
ive plowed snow with a couple different garden tractors. a Bolens, a cub cadet, John Deere, Wheel horse and an old speedex. the bolens pushed the worst in my opinion because the plow attached to the front axle. so when you got a load on the blade, it would lift the front tires up not allowing you to steer. but the locking differential on the bolens was a great thing to have when really moving snow. overall it was an okay tractor to plow with. Cub Cadet is a good tractor to plow with since the blade is so heavy and overbuilt it really works well. i used to have a John Deere 140H1 with a snow plow that attached in front of the axle with quick attach points, but it was so heavy it didn't lift the front axle it just pushed. i loved it. shouldnt have sold it. wheel horse plows are the best because of the rear axle mount...only thing i don't like is they don't lift very high and you lose all your clearance underneath the tractor. just my opinion.
I had a WH with a snow blade and it worked great. It had a hydro lift although not very high and a manual angle lever that you could change from the seat. I plowed a lot of snow with it and rally liked it.
1811 Hydro "Failing to prepare is preparing to fail". ![]() |
Yep, the wheel horse angle set up is the best invention since canned beer.
