Flatbedford if that is the original engine there shouldn't be balance gears in it.
149,682,1641,1711 with a 12hp in it 1 8" brinly plow 1 10" brinly plow 451 snow blower,H-48 International snow thrower 42" york rake with fold down grader blade. |
Please explain this to the new guy. Are they only in later engines?
Steve, Former multiple 149 owner. Left the tractors back east when we moved to Nevada. One went to South Jersey, the other to Long Island. |
Only the later engines had ballence gears. Dave Kirk knows more about kohler k-series engines than kohler and he created the original crank ballence kit http://www.kirkengines.com/
Where is the dipstick for your engine? If it's at the top under the hood, it won't have balance gears. If it's on the side by the carb (cam gear cover), then it originally had balance gears. They moved the dipstick to the cam cover because it would interfer with the gears otherwise.
Josh Diesel Cub Cadets........... |
Clay |
Tim Proud to own a 1965 Cub Cadet 122. |
I'm assuming the casting was changed. Just looked at the 169 and there was no provision for an upper dipstick. The 124 and 109 both have the upper dipsticks and it was too late to check the others in the shed. If time allows tomorrow, I'll check the 129 and 149 tomorrow. On a side note, correct me if I'm wrong, but I believe that none of the 7 or 8 horse motors ever had balance gears, only the 10+ horse motors. IIRC, when the 147 came out, they had the top dipstick with a stub dipstick to allow the owner to fill the oil from there and the bottom camcover dipstick to actually check the oil. The stub dipstick on the top allowed room for the balance gears. I may be off on these two details so someone please correct if I'm wrong. Merry Christmas everyone!
I just picked up a 149 yesterday. It has the dipstick on the carb side. I guess I'll be going in for the balance gears. I think the engine will coming out to do some other stuff anyway.
I doubt they would have changed the casting. It's the same casting, but machined differently.
