Go Back   Only Cub Cadets > Cub Cadets > Cub Cadet Engines > Onan Engines
Old 12-30-2011, 01:36 AM
72-149's Avatar
72-149 72-149 is offline
Default 982 w/Onan questions
It was running fine the other day. Then I went out there today, it fired right up, let it warm up, pushed some lite snow & it was acting up but not at first. This is how it was running ...mmmmmm stutter mmmmmm stutter mmmmmmm then it was fine shut it off & started it back up to go across the road to hit the neighbors drive way. I made it to the end of mine, cut right off, no dieing, just off. I checked spark - none. I pushed it back in the garage and pulled a plug. It wasn't fouled, smelled good, and was clean. I checked spark on plug none. I took points cover off and didn't see any spark there ether. I thought it was coil maybe but for sh**s & giggles, I took a piece of sand paper (220) lifted the contacts on points clean them off. It fired right up ???? still has a miss every now & then but not regular. I'm thinking its time for plugs wires & coil & points. They are all original and it has 500 HRS. On it the plugs might have been changed, but I don't think so. Are the points suppose to spark real bad at the contacts. I don't think so but just want a second opinion .
Old 12-30-2011, 02:15 AM
CCSuperMan's Avatar
Originally Posted by 72-149 View Post
it was running fine the other day then went out there today fired right up let it warm up pushed some lite snow & it was acting up but not at first ,this is how it was running ...mmmmmm stutter mmmmmmstutter mmmmmmmmmm then it was fine shut it off & started it back up to go across the road to hit the niebors drive way made it to the end of mine cut right off no dieing just off ,checked spark none pushed it back in the garage pulled a plug wasnt fuled smelled good was clean,checked spark on plug none ,took points cover off didnt see any spark there ether,thought it was coil maybe but for shits & giggles i took a pice of sand paper (220) lifted the contacts on points clean them off .it fired right up ???? still has a miss every now & then not regular. im thinking its time for plugs wires & coil & points there all orginal it has 500 HRS. on it the plugs mite have been changed i dont think so.are the points suppose to spark real bad at the contacts ,i dont think so but just want a second opion .
Hm .............how was that running ??? mmmmmmmm stutter mmmmmmmstutter mmmmmmm ? Im thinkin you're on to sumppin 72 !!
Old 12-30-2011, 03:05 AM
72-149's Avatar
maybe i should smack it & tell it to spit it out porkey !!!!
Old 12-30-2011, 09:02 PM
Push up to the top. Come on you Onan guys help out 72 if you can. I have no history with Onans so I am of no help.
Old 12-30-2011, 10:35 PM
ajgross ajgross is offline
Inactive Member
I would check the wire going to the points first. I had a issue with my 982 where the insulation had a wear spot that started grounding. I remember someone else had the same issue.
AJ
Old 12-31-2011, 04:37 AM
72-149's Avatar
AJ
that would make it run funky like that
Old 12-31-2011, 08:38 AM
I agree with AJ. I didn't do anything to my 982 yet but when I do I think I will order the Onan stuff from here.http://www.kirkengines.com/
I like the dual super coil and points saver ignition setup.
Old 12-31-2011, 11:52 PM
72-149's Avatar
i didnt see any thing on that site that said ONAN just kohler .the dual coil looks like a harley dyna ing. coil
Old 01-01-2012, 10:12 AM
Having problems with your glasses
From Kirks website: The PointSaverTM keeps your Kohler or Onan engine running like it just received a fresh tune up – for the life of the engine!
Oh look one more :
Dual SuperCoil for Kohler and Onan Opposed Twins
Why pay over $120.00 for a factory replacement coil when this high quality part is available for less than half the price? The Dual SuperCoil is made especially to our specifications and is wound with a high resistance primary of 3.2 ohms (same as the Bosch Blue). This gives a higher secondary voltage than the stock coil for improved performance, yet is not detrimental to breaker point life. No external ballast resistor is required. Epoxy-potted windings yield maximum resistance to vibration. Made in U.S.A. by a major coil manufacturer.
Dual SuperCoil price each - $60.00 plus $11.00 USPS Priority Shipping
Hope this helps.
Old 01-01-2012, 10:18 AM
riesedesperado6170's Avatar
riesedesperado6170 riesedesperado6170 is offline
I would check the points to see if there is oil film on them. The dealer told me when my Onan was still alive, they had issues with them getting oil coming up though the points rod. So I would try cleaning them before spending money.
