Old 01-01-2012, 12:32 PM
scottdaleguy scottdaleguy is offline
Question MTD creeper gear
another question?
can i use a aluminium mtd creeper gear in a 86?
ive been reading here and it seems i will need a creeper to use a tiller
Old 01-01-2012, 12:36 PM
I don't see why not. You will definitely need it for the tiller.
Old 01-01-2012, 04:19 PM
jbollis's Avatar
jbollis jbollis is offline
MATT,
Will the aluminum creepers from say an 1806, bolt up to and work correctly any of the older cast iron gear drive rears ?
Thanks
Sold everything but one.
Old 01-01-2012, 04:34 PM
I haven't tried it yet, but they have the same bolt pattern, the guts are the same, etc. The only difference appears to be the lubricant specified...85W-140 for the CCC one, for some reason.
Old 01-01-2012, 04:38 PM
jbollis's Avatar
Well that will help me out on my project. Now I just need to find a cast iron gear drive tranny and rear to put the big fine splines and carrier in from this 1862 parts machine I have
Old 01-01-2012, 07:23 PM
Joe,
I am pretty sure Eric put an aluminum creeper in the cast rear 582 he had but since sold and everything worked.
Old 01-01-2012, 08:01 PM
juniors1282's Avatar
Joe, It worked just fine. No problems at all.
1966 IH cub cadet 102x2
Old 01-01-2012, 09:05 PM
jbollis's Avatar
Thanks guys.
Now just to find the trany and rear.
Old 01-02-2012, 07:53 PM
cub1782's Avatar
cub1782 cub1782 is offline
My 1986 1606 had a cast iron creeper on a aluminum rear.
Logan Pfeiffer
1986 cub cadet 1606 w/ spring assist, cat 0
1974 cub cadet 149 sleeve hitch
1984 gravely 5665 professional
1979 gravely 8122
1979 gravely 8102
2000 Exmark lazer Z
1978 international 184
Proud to be a member of the FFA
Old 01-13-2012, 02:29 PM
Smile ccc creeper to cast tranny
ok guys i got the ccc creeper gear assy off the auction site...
was pretty clean inside other than a little lay on the spirol pin on the small gear
i found the spirol pins ay mt local hardware store... as well as the detent ball for the shifteri..(i dropped the one that came with it and never saw it again...)
the pins were very reasonable i thought at 1.69 for the 3/4 ones and1.99 for the 1 1/4 ones
here are a couple pics cause i know how u guys love the pics
