Old 12-24-2011, 09:45 AM
krhoover krhoover is offline
Dang it, I wish I would have kept the plow off of my wheel horse.
Old 12-24-2011, 05:02 PM
The cub looks good pulling the WH around!
Old 12-25-2011, 11:49 AM
riesedesperado6170's Avatar
riesedesperado6170 riesedesperado6170 is offline
looks good i used wheelhorse blade on my 73 works good but ground clearance isn't much got hung-up on the rails more than once
Old 01-09-2012, 01:14 PM
This QL1000 was purchased with no attachments because I had a Cub Cadet 42" blade. I was never happy with the blade for several reasons;
*Only 42"
*Lack of steering when pushing hard
*Corner droop
Well, I have several (6+) hours of serious pushing on the rear mount 48" blade now.
I ended up using the mower lift brackets for the blade lift.
The mounting turned out to be ridiculously strong!!
I love it. Since I had a 42" Cub Cadet blade on this tractor just before the rear axle mount, I was able to have a close comparison.
The biggest advantage of the rear mount is the capability to steer with the blade down.
The Cub Cadet blade either lifted the front wheels, or lifted the blade.
The rear axle mount seems to just push through tough situations.
The lift height remained the same at 6". The major difference is the blade corner does not "droop" when angled like the Cub Cadet blade does.
Saturday I finished reinstalling the blade angle control. No pics yet.
All in all, I consider this a most successful upgrade. I have moved a lot of dirt, compost, mulch, leaves and brush so far. Sorry, no snow yet!!
This combo really fits my needs where my 584 IH would do as much damage as work because of its large size. The QL1000 with its rear mount blade will see a lot of work in the future.
I think it will do a great job with snow, especially since I do not have to deal with the blade corner droop, which was always a problem area of the previous blade.
Oh yea, check out the QL1000's new WIRE GRATE Grill!!
It is made out of a piece of shelving.
Man I hope to paint this thing soon!!
Old 01-09-2012, 01:22 PM
Awesome work! Just goes to show that when you have the skills, tools, vision some impressive things happen!
Old 01-09-2012, 04:07 PM
I really like your work and write up on that. I think I like that set up a lot more than the cub style. Now if I could get you to make a set up like that with a 54" blade to fit a Super. Oh for free.
Old 01-09-2012, 04:38 PM
I've also enjoyed this thread! Top notch job, CADplans!
Old 01-09-2012, 05:36 PM
If the angle control works anything like the one did on my wheelhorse, you have the best blade setup ever made, I really miss my Wheelhorse for snow, it pushed circles around my cub. (sorry guys) I would like to see the angle setup, so some close ups please.
Old 01-09-2012, 07:50 PM
robpa robpa is offline
Ive been plowing backwards with the TO35 for 30 years and cant stand always craning my neck around. Im puttin a blade on thje front of the cub, I dont think I want to use the snowblower, my driveway is ruffer than a cob.
Old 01-11-2012, 09:18 AM
Here is a close up of my new grill.
This piece of shelving must have been case hardened, 0.200" diameter wire, and I almost could not bend it!!
I wanted a grill with more air opening.
