Old 01-16-2012, 04:45 PM
Tater305's Avatar
Tater305 Tater305 is offline
worked on the 129 today got the carb apart and soaking, pulled the mouse nest out, the gas tank was clean but i cleaned it again anyway, cleaned the wire connectors and got it to crank but its not getting power to the coil??? any ideas on were to start? I did pull the head of and cleaned it and the piston they werent very dirty but I did it anyway and found the motor has been rebuilt once already .10 over, checked the transmission it has the right amount of hy-tran in it but I do believe it has the wrong filter I couldnt find on it anywhere the words hydrolic transmission filter or cub cadet so that needs changed before I use it to much. My goal right now is to just get it running and driving then I will change everything. its one step at a time cause right now i already need fluid and filter for both tractors.
Old 01-18-2012, 04:20 PM
Tater305's Avatar
well after days of cleaning and checking I finally got the 129 running and driving. It still needs some work like it not wanting to idle but I'm pretty sure it has something to do with the points cause it pops and idles ruff but once you run it half open or more it smooths out and sounds great. the hydro needs some work cause it will speed up on its own and its a little too fast but I dont think the filter is the right one, it needs changed anyway so no big deal...but at least I can use it who knows maybe the blade off the 1862 will find its way onto it while I fix the M18 motor
Old 01-18-2012, 04:53 PM
Yeah put some new points and a condenser and set the timing and that should help a lot.
You will have to show us some pics of it.
Old 01-18-2012, 05:03 PM
PaulS's Avatar
PaulS PaulS is offline
Just think of your project as a diamond in the rust.
Old 01-19-2012, 01:11 AM
Tater305's Avatar
well here it is up and running. It still needs cleaned a little better but its in better shape now then when I brought it home.
Old 01-19-2012, 12:11 PM
Not a bad looking 129 at all!
Old 01-19-2012, 02:03 PM
Tater305's Avatar
thanks guys, this 129 is in far better shape then the last one I got it needed rebuilt again, it leaked oil, smoked like crazy and used more oil than gas, the generator was bad, never ran right wide open. So I would say this one is a step up in the world
Old 01-19-2012, 02:06 PM
Donny Curtis's Avatar
Donny Curtis Donny Curtis is offline
Glad it is going your way
Donny
Old 01-19-2012, 03:57 PM
I agree!
