Old 01-19-2012, 03:10 PM
4SPEED's Avatar
4SPEED 4SPEED is offline
Default 582 frozen rear end
this happened last year. and I cant find how the water is getting in.
the boot on the shifter is fine. and I dont have any gear oil leaking out on the garage floor in the summer. it does set outside most the time, under a tarp.
thank God for Glycol , or the cast on the inside would be rusted. the cover plate was rusted and has some pitting.
Old 01-19-2012, 04:00 PM
Looks like you did a great job of getting it cleaned out. Are you using Hy-Tran? Moisture could be getting in thru the breather hole on top of the casting.
Old 01-19-2012, 04:12 PM
You may want to remove the axles and pull the axle housings and drain out the sump of each housing. There is more than likely a good amount of contaminated fluid in those.
Old 01-19-2012, 04:23 PM
Here is your enemy!!
http://en.wikipedia.org/wiki/Condensation
A shed that controls air exchange is the only answer,
or move to a dry climate!!
Old 01-19-2012, 04:54 PM
Wow, that was frozen! Glad you got it cleaned out.
Old 01-19-2012, 04:59 PM
4SPEED's Avatar
I thought that too. but it cant be . there was so much water in it the oil was coming out around the shifter.
I woud think any condensation would evaporate with each use in the summer.
as it warms up from use.
Old 01-19-2012, 05:00 PM
TEET's Avatar
TEET TEET is offline
I agree with Methos...check your breather opening, or try to keep that area covered when storing if possible. It also looks like the gasket sealing your shifter assembly is leaking, sans the fluid shown in your pic running down, it may be entering around the bolt holes there. When was the last time you changes the hytran and filter? Perhaps its been like this for quite some time?
Good luck,
Jeff (teet)
CCC 1211
71
127
102
122
1962 Original
Old 01-19-2012, 05:04 PM
4SPEED's Avatar
Attachment 19829
I did jack it up , leaning it over . that did drain a lot of it out. im sure there is still some in it. its due for some work after winter. it needs a new brake and a paint job.
Old 01-19-2012, 05:07 PM
4SPEED's Avatar
hytran and filter? OK new guy here... didnt know there was a filter in there.
Old 01-19-2012, 05:10 PM
Your manual transmission doesn't have a filter, only the hydro's do.
