Old 01-20-2012, 09:09 AM
nikster's Avatar
nikster nikster is offline
Default ? Quick re-lease for a # 122 ?
Manual shows in mounting a snow thrower that there are 2 variants. An earlier bolt on to the frame for the QA36A snow thrower & an older 2 hole bolt mounting system.
Was wondering if there is a add on type re-lease that can be bought to add on the # 122 frame ?
Or if they even can be purchased?
Nik,
Old 01-20-2012, 12:25 PM
cubs-n-bxrs's Avatar
Nik,
Nik I was going to try that same alteration as you are talking about. I cut up an old frame to get the quick release piece off of it. I still have that piece if you need it. You will also need to mount Frankenstein bolts on the frame also. I was going to mount a QA36A on my old 102 but sold the tractor. I have a new found love of the 82 series machines so I have got rid of all my narrow frames except for my 124 and 125. 124 soon to be gone.
Old 01-21-2012, 07:03 AM
nikster's Avatar
Check your PM.
To mount the quick release onto my narrow frame will have to be a future project, we had 7" dumped on us yesterday & I have to get this thing throwing snow pronto. The older I get I seem to be that white stuff.
Grinding the welded posts on the QA36A snowthrower so that it would fit on the narrow frame, I improvised & fabricate a piece so that it would mount onto the lift arm. Not preety but in a rush it will do & does the job.
The snowthrower had 2 1/2" bolts welded, so that it would fit in the cradle of the quick release., I air ground the bolt's off for that needed hole, so it would mount on the frame.
Nik,
Old 01-21-2012, 10:29 AM
nikster is the QA piece you are referring to? Not sure I have the return springs but they can still be had at a Cub dealer or the sponsors what ever is easier for you.
Old 01-21-2012, 05:52 PM
nikster's Avatar
Yes indeed, that's it!
I PM'ya.
Nik,
