Old 01-24-2012, 11:23 AM
superSSlow superSSlow is offline
Thumbs up cub 106
I picked up a Cub 106 on Craigslist last week. plan on doing a full restoration over the summer. It has the original IH plow for it. It ran fine, no smoke. I took it home, used it for one day, and then it stopped working. My first thought, it was the battery, but now after charging it, I'm thinking its the starter. Now I get a click and that's all. I've cleaned all the connections on the wires and the starter it gets hot and that's about it. any suggestions?
ih cub 106 with plow
Old 01-24-2012, 11:25 AM
The starter shouldn't be getting hot.
Old 01-24-2012, 11:34 AM
the starter only gets hot on the terminals and that's when i try and start it a few times but again it just clicks and that's all. i haven't had a chance to really mess with it yet but im not sure where to start either
Old 01-24-2012, 05:27 PM
jbrewer's Avatar
jbrewer jbrewer is offline
Default Clicks
Are you saying it doesn't turn over at all? Just that the solenoid clicks ?
Is the engine free? Can you turn it over by hand?
Which terminal is hot when you try and start it? Battery, solenoid or starter generator? Have you cleaned the terms at the S/G end?
John
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
It's only original ONCE!
Old 01-24-2012, 10:11 PM
cubguy's Avatar
cubguy cubguy is offline
one of my Gts started clicking. It turned out to be the switch. if you have an extra switch laying around, give it a try.
Nroakes
Cub Cadet 3206
Allis chalmers B112
One big Green tractor
