Old 01-30-2012, 01:37 PM
cub149's Avatar
cub149 cub149 is offline
Default heim joints, what style?
I am getting ready to order some heim joints for my front axle tie rod ends on my 149 and super axle. I was looking at Mcmaster and they offer several different styles such as steel, high strength steel, bronze insert, some with teflon inserts for the ball and some with grease fittings. It's to much to choose from
The cheapest are the plain steel with either the teflon insert or grease fitting.
I would imagine you wouldn't want grease in them to catch all of the dirt
The bronze bushing ones are just a little more. What have any of you used?
Chip T.
Drexel NC
Old 01-30-2012, 06:18 PM
riesedesperado6170's Avatar
riesedesperado6170 riesedesperado6170 is offline
i am getting the ones with the grease fitting my self there cheaper and if you maintain it will last for ever.
Old 01-30-2012, 07:53 PM
cub149's Avatar
My thought on the grease fitting ones is that the ball is constantly going in and out dragging whatever sticks to the grease into the socket unlike other parts i.e. spindles that just turn turn and turn.
But you are right, keep up with them and it should be good. They are $3.00 cheaper so every two you buy you would get one free
Anyone else have a say on this?
Chip T.
Drexel NC
Old 01-30-2012, 09:01 PM
Oak Oak is online now
Chip, here are the ones that I used. I don't think you would be able to wear these out. http://www.mcmaster.com/#cadinlnord/60645k441/=g1ccrn
If you are going for original look then try these. http://www.mcmaster.com/#cadinlnord/6058k28/=g1cdr2
