Old 02-19-2012, 02:01 PM
Tater
My charge circuit is wired straight to the batt. I replaced the amp gage with a voltmeter.
Dave
The 1210/1640 is a vast improvement over the 1210 kind of like a Cyclops with a metal hood. I'd like to find a Super with the steel hood for my spare CH22.
Old 05-04-2012, 01:43 AM
Tater305's Avatar
Tater305 Tater305 is offline
ok well here is a up date for those who followed this swap. a couple things have changed first the motor in this picture is not the original one that was in it when i first swapped motors it is one i found later on and the motor that was in there was my back up for my puller so i didnt want to use it unless I had two, I got the heat shields built they dont look pretty but they do the job and u cant see them anyway with the panels on, i got the motor to charge so all is good there, got the pto to line up and the deck on it and have mowed with it with no problems, so far everything is as it should be except one thing i cant figure out this motor has a low oil indicator on it but when i hook it up to the light in the dash it stays on when running? no its not low on oil i checked I know the sensor is different cause this motor isnt pressure lubed like the kohler so that must be it? any body got any other ideas why? other than that one thing I like the tractor alot more I cant wait to get more seat time with it this year and winter
Old 05-04-2012, 11:59 AM
Looking good! Thanks for the pic and update.
