Old 02-19-2012, 02:58 PM
farmcat farmcat is offline
Default 102 Refurb
Well here are a few pics of my 102. Ive decided Im not going to do a total restoration this winter. My goal is to get it mechanically sound this winter and do a complete teardown next winter to clean, blast and paint. I also want to add a couple of options such as the hyd lift and the creeper. So I will need some time to assemble all the pieces. I am going to start with accessing what needs to be done. Carb rebuilt is on top of list, going through the steering is second. I will be posting as I go along for all of you picture junkies.
Old 02-19-2012, 03:03 PM
Nice looking 102!
You have a good solid tractor to start with.
Old 02-19-2012, 03:13 PM
Nice looking 102!
I agree and looking forward to your progress!
Old 02-19-2012, 04:24 PM
Thanks for the compliments.. well the steering is out of it...Going to order the rebuild kit...Carb kit, float, shutoff needle have all been ordered. Progress is underway.
Old 02-19-2012, 04:59 PM
4SPEED's Avatar
4SPEED 4SPEED is offline
I think you got a good plan. I wanted to do my 582 but putting it on the back burner another year. by the time I get this tiller and plow painted and ready to use , it'll be time to work the garden and mow the lawn.
Doug
Original , 100 , 125 , 582
Old 02-19-2012, 05:14 PM
Well ive got the steering gear apart, the only real play that I can see is in the bushing that goes into the housing for the pivot bolt. the cam follower does have a flat spot that I can clean up and the bearings look good. What is the steering upgrade kit that I hear some people talking about??
Old 02-19-2012, 06:30 PM
It's a thrust washer/bearing that mounts on the bottom.
http://www.youtube.com/watch?v=x9rGA_BePMo
Old 02-19-2012, 08:28 PM
VIOLATOR VIOLATOR is offline
Does the upgrade kit make a big difference. I have seen them on ebay and have been thinking about getting one
Old 02-19-2012, 08:46 PM
I put a kit on my 128. Albeit I haven't been able to check it with the engine and everything sitting in it, I can definitely say it is very smooth the way it sits. I also installed a bearing at the top of the steering tube instead of the OEM plastic bushing. Another cheap improvement you can do.
Old 02-19-2012, 09:44 PM
Fireman72737 Fireman72737 is offline
Nice 102. Looks like a good one. Low on rust.
Always Looking for More!
