Old 02-20-2012, 06:36 PM
Dave01's Avatar
Dave01 Dave01 is offline
Yes, when all that is holding the plug together is the boot on the spark plug wire it's probably time for a new one!
It always kind of amazes me how people try to stretch the life of spark plugs. If you can't put a few bucks into making your engine run well you better not complain about skips or hard starts.
1864 w/48" deck, 2084 w/54" deck + 54" blade, 3204 w/48" deck
Old 02-21-2012, 06:17 PM
Today I removed the CV joint for the steering on the 2284 to clean out the original grease and repack it with fresh grease. This is a fairly simple job anytime the engine is out of the tractor. Remove the battery tray, steering wheel, boot over the steering column, the snap ring that keeps the bronze bushing from sliding down the column and the bolt through the bottom of the CV joint. The CV joint should now slide up off of the steering valve or steering box. The joint has 4 allen head blots holding it together, remove these and the joint will come apart. Clean the old grease out, repack and reassemble in the reverse order. Also fixed the plug to the ignition switch while I was in the area. The battery tray will get the rust cleaned off and some new paint. Also replaced the crossover fuel line at the top rear of the fuel tank. The ignition switch is pretty nasty so I’m going to replace that also while it’s easy to get at.
Old 02-21-2012, 06:43 PM
Dave01's Avatar
Sam, any thoughts of adding front hydraulics while you are at it?
Old 02-21-2012, 07:52 PM
Dave
The 1882/2282 & 2284 will be for sale as soon as I'm finished with them. I doubt that I'd be able to recoup the cost of front hydraulics. As it is not many people will be willing to pay what I will have into these two tractors even though it won't be that much more that what TSC gets for a Cub lawn mower. The only one of the 3 that I'm going to keep is the 2182 and that's only because I think it's cool with the Kubota gas engine. Even at that it will get almost no use. I mow about 6 acres and this is what I use, I call it the grassanator. The hitch has been improved since that pic was taken. Kills grass fast.
Old 02-21-2012, 08:30 PM
Cool setup!
I guess you would need something like that to mow 6 acres! That's alot of yard!
Old 02-21-2012, 10:10 PM
Very nice, Sam! Thanks for showing us your pics.
Old 02-22-2012, 10:06 PM
plummcrazy1864's Avatar
plummcrazy1864 plummcrazy1864 is offline
Sam MAC let me know when your ready to sell. I live in the Galax area also.....hard to find supers around here. Especially ones in good shape.
B.D.Robinson
1996 Cub Cadet 1864/w 54" Deck
Old 02-23-2012, 06:00 AM
B.D.
Your welcome to come and take a look and pick the one you want. At the moment you can also see them with the sheet metal off so you can see everything.
Sam
Old 02-23-2012, 05:42 PM
The 2284 got it's new engine installed today. Took it for a little test spin. Sitting on the gas tank is not the most comfortable thing in the world. LOL Now I'm waiting for the sheetmetal to get painted and a new muffler. Should have it pretty well done by the end of next week. The muffler that's on it at the moment won't clear the hood. Just put it on for testing. Time for a cold one.
Old 02-23-2012, 08:15 PM
Frank1541 Frank1541 is offline
Sam,
Would the muffler clear if the inlet pipes did not curve up? Or is it just too wide for the side panels as well. I have an exhaust guy who can modify the inlet pipes for me.
