Old 03-13-2012, 08:06 AM
dsmithjr's Avatar
dsmithjr dsmithjr is offline
MattG,
Patton Acres aka quietline has one on ebay item number 230746395824 right now for $220 plus shipping and I figured with them being a sponsor they would have good parts that's what I used for a reference price. Welders around here will charge me a flat hour even if it only takes 5 minutes and that will be $50 or more depending on their mood. I may just pull it and bite the $$ bullet anyways and be done with it. I'm in no hurry to get it back together so I may tear it completely down and just start a rebuild. What other issues do you know about this particular model I should check?
Don Smith
Old 03-13-2012, 10:03 PM
squatch squatch is offline
Congrats on the new Super! Check for worn bushing and tie rod ends in the front end. I replaced my bushings and replaced the tie rods with Rod ends. There's a write up around here somewhere. Same with front wheel bearings. Check out the lift arm and make sure it's not cracked. Also check the gap on the PTO and look for overheating in the wiring connectors on the left side relay for the PTO and the ignition switch. Pull the starter and go through it per Matt's write up on here. The biggest issue may be the Walbro carb throw it away and replace it with a rebuildable and adjustable carb off a KT17. I also have a thread on that. Check my profile. If you need picture references feel free to browse this album. Pics of everything I've done to my 1872. Down to frame and back a few times.
http://s172.photobucket.com/albums/w...cpZZ1QQtppZZ16
Old 03-13-2012, 11:00 PM
Yamaguy's Avatar
Yamaguy Yamaguy is offline
Nice super you'll have it fixed up in no time!!
Originally Posted by JALLEN View Post
Take a washer the size of the bolt and weld it to the bolt .i know it is broke off flush but this will work with a wire welder .then weld a bolt to the washer let it cool just a sec. Then it should come right out. The welding should not hurt the case i have done this a lot with good results .the bolts have lock tight and are hard to come out with out heat. Any ? Pm me joe allen
That is a great idea!!!
Dale
147-Restored___________________882 Diesel
Hydro lift (not installed)___________44" Deck
48" Deck_______________________QA-42a/b Snowthrower
Rear lift ________________________XMW cat-0 rear lift
Model 2 tiller____________________12" cat-0 Brinly plow
Old 03-13-2012, 11:29 PM
Congrats on the 2072 and parts tractor!
Old 03-14-2012, 08:23 PM
JALLEN JALLEN is offline
You can also use the rear housing from the parts tractor. You must change the gear reduction gears they are different. Just find you a hydro from a 149 and use the cast iron case you will still need to change all the internals but it will never fail again.just some more ideas for you. If you were closer i a good case one of each cast or al. Just trying to help out joe
Old 03-14-2012, 08:58 PM
dsmithjr's Avatar
Here's the plan so far DX3 is coming down Saturday with a welder to remove the bolts. After all the suggestions I may try to find a cast case and do a switch out over the winter. Is the switch out something that an average mechanically ability with average tools can do?
Don Smith
Old 03-14-2012, 09:13 PM
You should be able to do it. The gear reduction housing will have to come off and the gears changed.matt may have a write up on this if not vince o. Just done one and he may chime in on this it should be a straight forward change out. The reduction gears are diff. For the regearing for the 26 12 12 tires but you should be able to do it. Just keep the parts separate you also can take pics. For reference if you have ? You can look at them. Just trying to help joe
Old 03-14-2012, 10:05 PM
The only 'special' tool I can think of at the moment that you'll really need is a dial indicator and magnetic base to set the backlash, but even a cheap Harbor Freight one will do.
Old 03-14-2012, 10:07 PM
maddog784's Avatar
Matt does have a write-up on this. It's pretty good. Led me straight through it.
CCC 784 w/ Triple Hydraulics
IH 982
50C Deck
41" IH Rear Blade
QA42A Snowthrower
Old 03-16-2012, 05:54 PM
dsmithjr's Avatar
Default Fluid Part Number
Its been a long week, having a brain fart. Correct transmission fluid part number for the 2072 is 737-3062? Tired of searching and only find the hytrans debate threads
Don Smith
