Old 03-20-2012, 07:54 PM
Congrats on the repair. I can't tell from the picture but is the heli coil insert end 1/2 to 3/4 of a turn below the surface? That will keep the bolt from pulling the insert out.
Old 03-20-2012, 08:44 PM
jbrewer's Avatar
jbrewer jbrewer is offline
Default Been there!
I did this in a lower front motor mount (old style) on a 327 in a 57 Chevy. Naturally it was after the engine was in.... which meant I had to pull it again to get to work on the broken bolt...with the broken hardened steel easy out in the middle. I was able to get it out with small drill holes around the busted easy out.
Congrats on the fix!
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
It's only original ONCE!
Old 03-20-2012, 10:12 PM
Great job on the repair!
Old 03-20-2012, 11:35 PM
cub1450's Avatar
cub1450 cub1450 is offline
Glad to hear you got the cub up and going again.
Jed
1975 1650SGT Work In Progress
1974 108 (Mint) #510358
Old 03-23-2012, 04:30 PM
Jrobert Jrobert is offline
Yes, the heli is about 1/2 turn lower then flush. All is bolted back together, rear PTO installed. I did change all of the hyrdo fluid. The controls are very sensitive now. Is this normal?
Old 03-24-2012, 09:32 PM
gdheck's Avatar
gdheck gdheck is offline
Hi, I don't post too often, but I have some input for this problem. My favorite local mechanic told me to gas weld a flat washer, I prefer a fender washer, to the bolt and then weld a nut to the washer using a fillet weld on the outside of the nut. This eliminates having to weld down inside of the nut. This will still work with bolts broke off a little below the surface too. I have a lot of washers welded to nuts with a little stub of thread welded on the bottom to prove that it works too.
BTW, how many fellow machinists do we have on here? I noticed at least 2 that posted to this topic. It would be nice to see a machine shop area on the site. I know I have made several parts and tools for my Cubs and I'd like to see what some others are making.
