hey fellas. i told you previously about my new to me 122 with a pto in the rear end. what model tiller would i have to find to be able to use with my tractor. i am sure it would have to be a cub attatchment with the pto turning counter clockwise. let me know what you guys think. thanks for all the help
The tiller for these is run by the front PTO and a big long belt to the back of the tractor.
Matt/Buralcat......There is a PTO driven tiller for a cub cadet,IF it was made for a 122 I dont know!!!
Maybe Matt answered the question!!!!!LOL Jason
Jason Davis :biggrin2.gif: Just one more !!
SOMEONE on here has a PTO driven tiller for there cub.
Id like to know the answer to this question also!!! and the model # for the tiller. Then I can research it Off to parts look up I go,LOL
The rear PTO driven tiller is for the 2000 rpm PTO on the super garden tractors and does not fit a 122...once again, the tiller for a 122 is driven from the front PTO.
LOL Matt...........Once again !!!
Thanks
thank you for help. what attachments would hook up to my pto then? just curious, cause i would hate to have it and not use it
Pretty much nothing. They made a reverser for it to get it turning the standard direction and speed, but they're rare and expensive. Unless you have a small grain elevator or something, there's no use for it. There was a trencher attachment that might have used it, but I don't know for sure. There aren't many of those around anyway.
oh ok. thank you for all of your help matt. i just have one quick question for you? how hard is it to switch from a manual to an electric pto, and what would be needed. thanks again
On a 122? Don't bother. The block probably isn't drilled for the mounting bolts, you'll need to do a bunch of rewiring, and the biggest problem is that you'd have no way to start the engine because the PTO clutch will be occupying the space where the crank pulley for the starter/generator needs to be.
