When I bought my 782D, the PTO would only engage when the PTO switch was held in the up position. I assumed a bad switch so I just replaced it....and it's still doing the same thing. Thoughts?
149 (2), 125, 782 |
There's a relay on the left side of the dash tower that works with the safety interlocks - might want to check that out. Mine did the same thing when I first got it, and a wise man told me to start with the relay.
He was right!
CCC 784 w/ Triple Hydraulics IH 982 Cub Cadet Commercial H1748 Walk-Behind 50C Deck 42" Hydraulic Angle Front Blade 41" IH Rear Blade QA42A Snowthrower |
Thank you...will check it out!
149 (2), 125, 782 |
I had one that did the same thing I had also bought a new switch and relay that didnt fix the problem. The neutral safety micro switch for the hydro control under the dash was bad causing the issue.
Cub cadets 100, 128, 582, 1050, #2 tiller, 42" blade, 2-10" Brinly plow, 12" cat0 Brinly plow. |
149 (2), 125, 782 |
