Old 04-11-2012, 06:52 PM
cubpsycho cubpsycho is offline
Default Hi all,,, ih question
HI Everyone:
Can anyone please tell me why this Carb is so expensive for my 123? The throttle linkage is shot and the Carb is just a mess. Upon pricing what little there is of these Carter Carbs, they are about $200.00. I don't understand my 124 isn't that much. The engine is a
Spec No-----4759B
Serial-------- CO52881
Model-----------K301AS
It has a Carter model N Carb
The only number anyone I have check almost everywhere is: 47-853-21S. Apparently the "21-S" is my problem. A rare one. Can anyone help?
Thanks guys,
JOHN
Edit: Removed Caps Lock....RBedell
Old 04-11-2012, 07:16 PM
Spec No-----4759B
Sorry, I don't know why they are so expensive, probably because few people are buying carbs for 50 year old tractors!!
P.S. easy with the caps!! few people will respond to all caps posts.
Old 04-11-2012, 07:21 PM
Merk Merk is offline
John,
I'm having the same problem with a carb from a K241 that I'm rebuilding for someone. The carb I'm trying to rebuild needs a throttle shaft. The throttle shaft is NLA. Plans are to modify a newer shaft.
You can replace the Carter carb with a Kohler carb. Make sure it's a #26 carb. It is a direct bolt on....may have to adjust the linkage. I would check with the sponsors at the top of the page. They should have a good or rebuildable carb for your Cub.
Old 04-11-2012, 08:33 PM
Default thanks
thank you for the fast reply, someone had told me that the choke 0n the 21 is different from the 26, in that the choke cable will pull from the top instead of the bottom, making a problem for re-routing on the this, do you think there is any truth to that>? thanks again, john
Old 04-11-2012, 08:35 PM
Mabye so, but there still money makers!!!!!!
Old 04-13-2012, 04:29 PM
by cubpsycho
You won't have a problem if the carb came from a Cub Cadet. You can change the choke shaft if you find the correct shaft. Not certain...I think you can get the correct choke shaft from Kohler.
Old 04-16-2012, 08:56 PM
Default Kohler #26
so you think the #26 is the good choice? thanks
