Old 04-20-2012, 02:58 PM
jluster jluster is offline
Yeah I wondered about that rear end myself. I just pulled up the service manual for the 772 which I was told was very similar to my 882. The manual has installation instructions for a rear PTO and 3 point hitch! The hitch looks like it will hook up to the tiller. I doubt the PTO would drive the right angle box but the box could then sit on the rear end and the hitch could carry the tiller possibly. It looks rather interesting.
129, 109, 1200 x 2, 1650, 882, 1450
2A tiller, 50" & 44" decks
Brinly 12" plow
Brinly Disc Harrow
Snow Plow
Joe Luster
Cincinnati
Old 04-21-2012, 12:29 PM
Joe where is the gas tank at? If it's on top of the rear end I don't think you'll have room to mount the top casting for the rear lift.
Old 04-21-2012, 01:35 PM
Joe I wouldn't trust a tiller on that Alum. rear end.
Why not? Works great on mine...
jluster-
You need a Cat-0 3-point hitch for the diesel. If you want to use one of the older belt-driven tillers, there is an adapter package to use it on a tractor with a Cat-0 hitch, but that adapter package is hard to find. I wound up making it. Details are on my website.
Old 04-21-2012, 02:24 PM
Attachment 23566
jluster-
Ahhh he's wanting to convert it to cat0.
Old 04-21-2012, 08:11 PM
ajgross ajgross is offline
Inactive Member
I just got the tiller running on my 682. I would be willing to trade the 682 with a tiller for a 882.
AJ
Old 04-21-2012, 10:18 PM
mrcubcadet's Avatar
AJ
Sounds like a deal to me, Jluster!
I believe AJ is serious!
-105___ Tiller
Old 04-25-2012, 11:45 AM
I know Doug (4SPEED) will trade a lot for that 882 as well! I am going to start looking for these attachments 3 point and tiller adapter. But I think I will keep the 882 for a while before I give up on it as my true garden tractor for tilling and plowing.
It does need some work. Can hardly steer it, tires leak, throttle needs to be held up with a wire, and needs new PTO switch. Basically I would rather mow with my 129 than the 882 at this point but the 882 will climb the hills (with chains and rear wheel weights) that the 129 will not.
I think I will try to get my 1200 running soon and see if I cannot get the tiller on it. Boy if the motor in my 1650 would turn over, I would have better hope for the tiller on it.
Brinly 12" plow
Brinly Disc Harrow
Snow Plow
Joe Luster
Cincinnati
Old 04-26-2012, 07:11 PM
Inactive Member
I didn't figure you'd let it go, but I thought I would throw it out there.
AJ
Tags
#1a, 129, 1650
