Old 04-21-2012, 07:36 PM
ajgross ajgross is offline
Inactive Member
I did get it bolted back into the tractor yesterday afternoon, man that rear bolt on the starter side . Wow, I had to walk away from it for a minute, and take a break.
Sounds like you tried to bolt the engine to the engine plate with the plate already in the frame. It's much easier to remove/install the engine when it is attached to the plate.
AJ
Old 04-21-2012, 09:03 PM
MWShaw's Avatar
MWShaw MWShaw is offline
AJ
NOW you tell me!!!!!
Old 04-21-2012, 09:09 PM
Yep it's easy to pull or replce when you remove the 6 bolts from the plate.
Old 04-21-2012, 09:14 PM
MWShaw's Avatar
Short nipples? don't need no short nipples ha,LOL!
Thanks George, and to show my appreciation, I post up that nipple pic.
You ever see a Cub with such pretty -------?
A little progress tonight, getting closer. Here's the plate where the remote filter head mounts;
Filter in place;
I know the lines are going over the drive shaft, but I think it will work.
Next I took Matt's advise and relocated the hour meter under the hood. Then put the oil pressure gauge in it's old position. Thanks Matt.
I don't have to work tomorrow, so hopefully I can finish it up.
Old 04-21-2012, 09:58 PM
Thanks for the great progress pics!
Old 04-21-2012, 10:07 PM
Looking good...If I were you'd I'd put a few washers between the bracket and the oil filter mount to get the lines a little further away from the driveshaft.
Old 04-21-2012, 10:17 PM
MWShaw's Avatar
The pictures are deceiving, there's a good 1.5" between that lower line and the drive shaft. My rag joint was shot when I pulled the engine, it was basically spinning on (1) of the (2) bolts.
Even as bad as that was it would not have swung far enough to hit the lines where they are at now. If you look at where the bracket attaches to the frame rail, I have it under the rail, I could move it the top, but really feel there is no need.
Old 04-21-2012, 10:27 PM
Ok, that's not bad...in the picture, it looked like there was about 1/4" of clearance with the bottom line.
Old 04-21-2012, 10:50 PM
MrGitrdone41's Avatar
I would like to put a oil presser gage on my 1812. How did you pulm the lines? could you get a pic?
1988 1812,dual ports
1973 108
1968 125
Old 04-21-2012, 11:36 PM
MWShaw's Avatar
http://www.summitracing.com/parts/EQU-6244
http://www.summitracing.com/parts/SUM-890091
I'll get more pictures tomorrow.
