View Poll Results: what is your favorite rattle can
Cub Cadet 4 17.39%
IH/Case 9 39.13%
Valspar 7 30.43%
other 3 13.04%
Voters: 23. You may not vote on this poll
Old 04-25-2012, 04:51 PM
machinehead323 machinehead323 is offline
Default spray paint choices?
I’m getting ready to do some painting of parts. The guy that I bought my 1650 from says he used Cub Cadet Paint to redo it. Those cans are like $15 bucks a pop and I have to order them. From the same place they sell IH/case paint at about $1 cheaper. I have a TSC in town that I can get the Valspar Cub cadet paint at and it’s only like $5 a can. I’m not going for a restore but I want a nice durable paint to go on it. I know auto paint will do way better than rattle cans but rattle cans is what I get to work with on a daily driver. So is the CC paint worth the 3x price tag. How close is the Valspar paint to the cub cadet paint? Know it probably would not match up painting a tower then a fender with two different brands. Though say rims compared to fenders is it close enough with the parts not being side by side?
1979 1650, #1 tiller with one extension, 90 degree box mounted, 3 point. 1961 4 digit bringing back to life. I have the mower and 3 pint for it. The 1650 is the fastest mower in the neighborhood.
Old 04-25-2012, 10:24 PM
I tried the Valspar, and it's close to a faded out tractor, but the Cub paint is much better, more money, but it's your dollar.
Old 04-25-2012, 11:10 PM
Valspar CC Yellow = wrong color for an IH Cub Cadet...it is sort of orange and matches the newer 2000 series tractors.
Old 04-25-2012, 11:20 PM
jlampe94's Avatar
jlampe94 jlampe94 is offline
I use IH Federal Yellow from the local Case Ih dealer, i think its like 7bucks a can, 15bucks a quart for non aerasol.
Original,100,123,129,1200,1250,168 in progress (3) 42inch plows, QA-42A,#1 tiller, 10inch brinly plow, Case Ingersoll 224, 1948 Farmall H, 1950 McCormick W-6, 1952 McCormick W-4.
Old 04-25-2012, 11:26 PM
The "biege" or cub cadet white that TSC sells is close enough to the earlier IH cubs to be a close match, but not for the brighter white of the late '60's/early 70's models. The cub cadet yellow has more orange in it, as Matt has already stated, and it is quite a stark contrast to the original paint on the IH models.
Old 04-26-2012, 07:20 AM
Actually that matches the white on the 1x8/9 through 82 series better than the earlier white; the earlier white has more of a greenish tint to it, but after 40 years of fading you wouldn't notice. There were three shades of white used: IH 901 from serial number 501-218009 and has a slight greenish tint; IH 902 was used from S/N 218010 to 375938 and is the whitest of the three, but still not 'bright white'; IH 935 white was used from S/N 375939 until the end of IH production of the 82 series, and this is the color that the Valspar 'IH white' is closest to, as it has a beige tint (very obvious if the tractor is outside in the snow). I haven't seen anything to confirm this, but I'm pretty sure CCC used the same shade of white through at least 1985 and probably through 1989.
Old 04-26-2012, 07:30 AM
Mountain Heritage's Avatar
Cool
I didn't realize there were 3 "900" series white paints used Matt. Damn! Learn something new everyday! I should check again which one I bought in a spray bomb to paint my sleeve hitch. Was going to use the same can to touch up the front rims on my 100....might have to change my mind on that one possibly depending on which one I had bought.
If I didn't want to sand blast my front rims....you guys have had success on just roughing up the paint with sand paper and cleaning off any surface rust before prime & paint??
Mike
Ontario, Canada
Now everyone wants a Cub!
Beware of the Wife
Old 04-26-2012, 09:01 AM
cubby102's Avatar
cubby102 cubby102 is offline
i use the case/ih federal yellow and is close enough for me runs about 10 bucks a can but lays on really thin but a can will go a long way, i think i used two cans on my 102 and did everything but the engine
Old 04-26-2012, 11:07 AM
TommyK's Avatar
TommyK TommyK is offline
+1 to what Matt said about the TSC white matching the 1X8/9 series. I used a can to paint the housing grill on my 108, matches perfectly. I used a can of the TSC CC yellow in battery housing, it's definitly more orange than yellow. I wouldn't use it anywhere that it will show.
Old 04-26-2012, 11:21 AM
Ok so TSC CC yellow is worng, but the white works on the 1x8/9 through 82 series, correvt (im working on a 1650) When yall talk of the TSC paint are you referring to the Valspar tractor and implement paint they sell in the rattle can? I just called the Case dealer in town and all they have is John Deere yellow, WTF! and no white. i dont have a CC dealer here either. while im at it, what is a good primer to use as a base. I just got a new blast cabinet so the heavy parts will be nice and clean.
