Old 04-27-2012, 08:54 PM
Originally Posted by jkier View Post
If anyone's interested Kohler's part # 47 411 04-S Point Rod
Measures 1.552" with a decent pair of dial calipers
Interestingly my Cub dealer informed me the old rods were part aluminum and part steel and would mushroom on one end causing this timing problem.
I'm keeping my fingers crossed that's whats happened
What's the exact diameter of the new one?
Thanks
Old 04-27-2012, 09:07 PM
jkier's Avatar
jkier jkier is offline
Thanks
I'll check that in the morning for ya.
The minute posted the length I knew I should'a measured the diameter
106 Needs a clutch-------107 (Lent to my brother)
123 w/hydro lift & qa36--126 w/creeper and lift
127 restored--------------129 50" mowin machine
129 w/hydro lift-----------147 plow horse w/tiller
149 auction score---------782 KT17SII
Old 04-27-2012, 09:54 PM
Thanks
Old 04-28-2012, 07:25 PM
jkier's Avatar
That took a while.
Both the new an old measure 0.185" in diameter.
The old aluminum and steel rod is actually longer than the new one, didn't look mushroomed.
It measures 1.562".
Unfortunately it doesn't look good for the old 10 horse
Still can't seem to get her running smooth, gonna have to tear her down.
Now I have to swap the tiller to the 147 and put the deck on the 127...
Old 04-28-2012, 07:37 PM
Is it possible that an incorrect, but "close" looking set of points were installed!!??
A new set of points may do it, possibly something on the point set is bent!!??
Look for the non-obvious!! Then take pics, we need the edukasion!!
Old 04-29-2012, 07:31 AM
jkier's Avatar
I'll have to try swapping the old points back in.
I'm gonna take a video!
Old 05-07-2012, 12:49 PM
jkier's Avatar
Well, no need to worry about the timing now.
Seems the piston gave up the ghost.
Blew the skirt right off the piston, marred up the top of the cylinder wall.
Worst part is it looks like she's already 30 over...
Old 05-07-2012, 01:01 PM
With you needing to get the tilling done, I guess the piston blowing was ,,,,
bad timing!!
Sorry about the piston, could not resist!!
Old 05-07-2012, 01:39 PM
jkier's Avatar
bad timing!!
Bad timing all around.
The ol 147 developed a hydro leak, need to tear into that.
Screwed up the PTO on the 127, destroyed the bearing and pressure spring.
and the electric lift spiriod gear lost a couple of teeth and won't lift anymore.
Old 05-07-2012, 01:58 PM
Yikes everything going bad at once sucks. Sorry to hear the bad news.
