Old 04-27-2012, 10:35 PM
mrcubcadet's Avatar
Default CC 1200 (1600) Project
Well, as some of you might have saw...I have been looking for a WF roller, to put a freshly rebuilt .020 over K341 in, out of my 1650.
I was planning on fixing the 1650 that it came out of...but got looking at some of the places where the motor mounts have put holes in the frame (wear over time) and decided to get a different frame, and to get away from the ISO mounts.
Joe (Jluster) and I have decided to do some trading, and tomorrow I am getting his 109 with a blown motor. My plan is to put the K341 in it.....with a 3 speed/clutch from a 124. Then I will call it a 168...
Will try to get some pictures tomorrow when Joe gets here.
-105___ Tiller
Old 04-27-2012, 10:48 PM
Sounds like a good plan.You will have to change the brake lever on the brake pedal rockshaft from a gear drive also.
Up to 534 and counting...
Old 04-27-2012, 10:54 PM
I wonder if the clutch out of a 1806 was much different than the 1x8's.
My first Cub Cadet was a "148" built from a 86, and I tried everything except a new spring to keep that clutch hooked up!!
The clutch would just slip in third gear. Very disappointing build.
I did ask a lot of that tractor though,,,
It may have been due to my fluid filled tires, lots of inertia to overcome.
My QL 1000 will do more than the 148 would do.
Old 04-27-2012, 10:55 PM
jlampe94's Avatar
jlampe94 jlampe94 is offline
Heavier spring for the clutch might also not be a bad idea with the extra horsepower, sounds like a cool project!
Original,100,123,129,1200,1250,168 in progress (3) 42inch plows, QA-42A,#1 tiller, 10inch brinly plow, Case Ingersoll 224, 1948 Farmall H, 1950 McCormick W-6, 1952 McCormick W-4.
Old 04-27-2012, 11:03 PM
mrcubcadet's Avatar
Thanks! I suspect it will be mean with a 12" plow!
I have 3 bare wide frames that were gear drives. I can get the lever from one of them.
Interesting...maybe a 1806/582, or even a pulling spring.
Will defiantly have to look into putting a heavier spring in it. And thanks! Always have thought it would be cool to try it!
-105___ Tiller
Old 04-27-2012, 11:06 PM
mrcubcadet's Avatar
Maybe Dale (Merk) will chime in. He once told me about using a cultivator spring.
-105___ Tiller
Old 04-27-2012, 11:15 PM
mrcubcadet's Avatar
Here's the medium-duty spring Chris Westfall sells..... http://www.cubclassics.com/BLUE%20CLUTCH%20SPRING.JPG
-105___ Tiller
Old 04-28-2012, 08:16 AM
The 1806 and 582 still use the same clutch as the WFs, essentially, and the spring is not strong enough to put 14+ hp to the ground, IMO. Get a stronger spring and it'll be fine. I have the red spring in my 582, and I use a locking collar behind it instead of the roll pin so I can adjust it. I have it compressed 3/4" instead of 1", giving me about 650 lbs instead of the stock 250-300 lbs, and it's not noticeably harder to push the clutch in. That's what I'd recommend.
Old 04-28-2012, 10:56 AM
mrcubcadet's Avatar
Would the blue medium-duty spring from Chris (600lbs I think) do it?
And, just got to thinking...is a clutch/drive shaft from a NF (124) different?
-105___ Tiller
Old 04-28-2012, 11:35 AM
ihnick's Avatar
ihnick ihnick is offline
I was planning on putting that blue spring in my 108 when I put the 14 in it. Id like to know some feedback on it as well
As far as the 168 project goes, this is gunna be fricken awesome
Nick.
