Old 04-30-2012, 09:58 PM
Originally Posted by mrcubcadet View Post
I think he's saying that if you have the rubber ISO's...then you will need the ball bushing driver, because of the motor moving. If you have solid ISO's...then you could get by with a NF or WF driver, because of less movement.
I don't think it moves that much.
Old 04-30-2012, 10:22 PM
jlampe94's Avatar
jlampe94 jlampe94 is offline
Here's what i did to my 1200, free for me, easy to do and i dont think its ever going to wear out. 1/4" plate welded in the frame, laying flat in there it put that engine at the stock heigth. As far as vibration is concerned i dont really notice it pretty smooth actually. Used a solid 3 pin driver and used double flex disks at the rear. Have some pics of setting it up cant find one of it conmplete tho
Original,100,123,129,1200,1250,168 in progress (3) 42inch plows, QA-42A,#1 tiller, 10inch brinly plow, Case Ingersoll 224, 1948 Farmall H, 1950 McCormick W-6, 1952 McCormick W-4.
Old 04-30-2012, 10:32 PM
Is that a deep sump oil pan?hard to tell...
Up to 534 and counting...
Old 04-30-2012, 10:33 PM
After putting the engine brackets back into a 1450 last week, I believe the parts used in the assembly could allow as much as 1/4" or more variation in the final location of the crankshaft of the engine.
This caused the requirement of the ball bushing.
I think to eliminate the ball bushing, and maintain proper driveshaft alignment, the engine would have to be custom fit into a Quietline chassis on a per unit basis, every machine would be different.
Old 04-30-2012, 10:41 PM
mrcubcadet's Avatar
This makes me feel a whole lot better about using the solid driver, and vibration concerns!
Have decided to buy the motor mounts off Ebay...after seeing this!
Thanks for the information, guys!
-105___ Tiller
Old 05-04-2012, 10:55 PM
mrcubcadet's Avatar
Got the K341 home today from having it rebuilt...
My wallet is now thinner!
-105___ Tiller
Old 05-04-2012, 11:06 PM
johncub7172's Avatar
Very spiffy! Great to see another Kohler motor rebuilt and going!
Old 05-05-2012, 12:48 AM
Looking good, Conner! You're ready to go now.
Old 05-05-2012, 01:17 AM
Conner it will be worth it the first time you fire it up!
Old 05-05-2012, 07:17 PM
dieseldan123's Avatar
I know that feeling!
1967 IH Cub Cadet 123
1978 IH Cub Cadet 1650
19?? IH Cub Cadet 682
