Old 05-06-2012, 08:51 PM
I find that pretty hard to believe. The disc is made out of very hard, non-metallic friction material. The later ones have a piece of it bonded to either side of a metal disc.
I thought it was the other way around??
The only ones I have found lately are the solid ones, without the steel center!!??
My local Cub guy said the metal center ones have asbestos coating, and work well, if you could find one.
Old 05-06-2012, 08:56 PM
travis.robben's Avatar
travis.robben travis.robben is offline
the reason it was rubber was that the guy i got it from his uncle had put that in there because he was to cheap to buy a new one
ihcadet
Old 05-06-2012, 09:04 PM
Nope, why would they put the friction material between two sheets of steel? That wouldn't make any sense...
The solid one are older...if you buy a new one it has 3 layers. I doubt there's any asbestos in those.
Old 05-06-2012, 09:26 PM
By other way around, I meant the newer ones are solid, no steel.
I purchased two from different sources and got solid ones from both.
Old 05-06-2012, 09:30 PM
Interesting...all of the ones I have bought from Cub Cadet have not been solid, and I don't think I've ever seen the solid ones on anything newer than a 1x4.
